1967 GTX Black Finish Paint #2553834
09/23/18 09:10 PM
09/23/18 09:10 PM
Danville, NH
Mopar_Mike Offline OP
Danville, NH
Hi All,
I have a nice hood trim molding I want to use on a 67 GTX. It is from a Belvedere so it has the flat black paint. Does someone make a good correct black with the grit to it paint. Same paint as used on the grille, headlight bezels, trunk panel etc.
Thanks!
fas141@comcast.net
RS23L7 4-Speed
Re: 1967 GTX Black Finish Paint [Re: Mopar_Mike] #2553851
09/23/18 10:08 PM
09/23/18 10:08 PM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
What you are looking for is called "Dark Textured Argent" It's the same stuff they use on 1971 Cuda grilles, and many other Mopar applications over the years. Try sixpackfrank@aol.com, he sells a nice mix.
Re: 1967 GTX Black Finish Paint [Re: ScottSmith_Harms] #2553993
09/24/18 10:43 AM
09/24/18 10:43 AM
Danville, NH
Danville, NH
Thank you Scott up
RS23L7 4-Speed
