Speedo Cable #2553675
09/23/18 04:08 PM
09/23/18 04:08 PM
Hamburg, Pa.
72 RR DUDE Offline OP
Hamburg, Pa.
Ok so on my 72 Roadrunner the speedo was making alot of noice and the needle was bouncing around alot. I changed the cable because the old one hardly turned when it was out of the car. Went to a car show yesterday and it did the same thing. I stopped and unhooked it under the dash and it didn,t do it from there on . Any idea,s what is going on???
Re: Speedo Cable [Re: 72 RR DUDE] #2553688
09/23/18 04:32 PM
09/23/18 04:32 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Try cleaning and lubing the cable core.
Re: Speedo Cable [Re: stumpy] #2553739
09/23/18 05:53 PM
09/23/18 05:53 PM
Hamburg, Pa.
Hamburg, Pa.
what lube do you think is best to use?
Re: Speedo Cable [Re: 72 RR DUDE] #2553747
09/23/18 06:12 PM
09/23/18 06:12 PM
RapidRobert Offline
RapidRobert  Offline
Your parts house will have some specialty lube for it (graphite based iirc). Did it start out of the clear blue (with no changes in that system)? If lubing the new cable does not relieve it then take your old inner core & cut it to a manageable length & use a reverseable drill & a helper to hold it & spin up the speedo (CCW) & see if the speedo head is the culprit.
Re: Speedo Cable [Re: 72 RR DUDE] #2553748
09/23/18 06:12 PM
09/23/18 06:12 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Graphite or a very light coat of white lube
