Need help of moparts
#2553668
09/23/18 03:33 PM
09/23/18 03:33 PM
Posts: 1,546 Michigan
Kiddart
I am in need of a 360-1 indy cylinder 1.6 rocker for my number 6 exhaust side. I called indy a few weeks ago to order one and they took all my info and credit card info but neglected to tell me they didn't have any in stock and are not making them any more, of course until I called them two weeks later when I got home from out of town. So now I have to spend $1200 on all new over the winter. I sure would appreciate it if I could buy someone's spare if one still exists.
they are blue in color and for the #6 exhaust valve.
thank you Moparts
Thank you Kiddart
Re: Need help of moparts
[Re: Kiddart]
#2553678
09/23/18 04:17 PM
09/23/18 04:17 PM
Posts: 20,145 PA.
pittsburghracer
Sorry I can’t help you now but I have a set on my Duster I hope to set over during the Winter. I bought a set of T&D rockers off another member that switched to a big block. Did you happen to compare an Indy exhaust rocker with a Craine rocker. Or maybe contact Dove as I’ve heard they made Indy’s rockers.
[Re: Kiddart]
#2553706
09/23/18 04:59 PM
09/23/18 04:59 PM
Posts: 1,454 Glendora Ca.
Just-a-dart
Glendora Ca.
PM me. I have a set with a couple missing
[Re: Kiddart]
#2553880
09/23/18 11:06 PM
09/23/18 11:06 PM
Kiddart
I will check with Dove as well. someone at Indy said if I went with the Jezel set I don't have to change my push rods. is that a true statement? wouldn't a offset 1.6 rocker for a 360-1 set up be the same across manufactures, after all they are adjustable.
I may not understand what would be different.
Thank you Kiddart
