Re: 440 Six Pack Upper Fuel Line Leaks [Re: Ghoste] #2570751
10/28/18 09:52 PM
10/28/18 09:52 PM
glendora, ca.
Deepockets Offline
Deepockets  Offline
glendora, ca.
Like said in an earlier post is that I'd found an impression in the steel fittings on the carbs. from the last tightening. Unless the flair lines up in the exact same spot, I'd get a little leak. I used these copper fitting seat washers and this is the first time they didn't leek with minimal tightening.
https://ibb.co/hCoo8A
Re: 440 Six Pack Upper Fuel Line Leaks [Re: moparx] #2570924
10/29/18 12:01 PM
10/29/18 12:01 PM
Canada
demon Offline
demon  Offline
Canada
Originally Posted By moparx
on some stainless line connections, i have had to tighten, release, and re-tighten several times to get an effective seal. grease on the threads and around the tubing helps to keep the tubing round and booger free. i don't know why stainless acts this way, unless it's the work hardening that occurs to the material during the flaring process, causes the flare to become slightly egg shaped, and the repeatedly tighten/loosen process restores the flare's roundness.
My experience with stainless lines, is that they leak at the flare. Stainless doesn't have any elasticity, and destroys the brass fittings.
I'll never use stainless on brake lines again, or any flare fittings like 6 pack upper lines.
