Who made the starter mounting brackets? #2552722
09/21/18 09:25 AM
09/21/18 09:25 AM
S.E. Michigan
ZIPPY Offline OP
ZIPPY  Offline OP
S.E. Michigan
A few years back someone here was selling brackets that enabled the end user to bolt a starter directly to the engine (la/b-rb) without a transmission, for test fire up and so on. Now im trying to find that and they aren't here anymore. What the heck.
Who was that? Are they still around?
Thx
Rich H.
Esse Quam Videri
Re: Who made the starter mounting brackets? [Re: ZIPPY] #2552737
09/21/18 10:32 AM
09/21/18 10:32 AM
s.w.fl
bonefish Offline
bonefish  Offline
s.w.fl
i bought one of those.cant remember the guy.it didnt work on a BB.what are you wanting it for? i might be able to dig it up.
Re: Who made the starter mounting brackets? [Re: ZIPPY] #2552791
09/21/18 12:13 PM
09/21/18 12:13 PM
S.E. Michigan
ZIPPY Offline OP
ZIPPY  Offline OP
S.E. Michigan
Test stand. But only if it works...guess that explains why the part isn't around anymore!
Rich H.
Esse Quam Videri
Re: Who made the starter mounting brackets? [Re: ZIPPY] #2552822
09/21/18 01:10 PM
09/21/18 01:10 PM
AndyF Offline
AndyF  Offline
I made some of those for Hughes Engines. Just a thick piece of steel that bolts to a few of the bellhousing bolts and provides a place for the starter to mount.
Re: Who made the starter mounting brackets? [Re: AndyF] #2552841
09/21/18 01:46 PM
09/21/18 01:46 PM
pittsburghracer Offline
I bought one from a member a few years ago. I made a post looking for the member that made the starter plates for an engine break in stand and he replied.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Who made the starter mounting brackets? [Re: ZIPPY] #2552851
09/21/18 01:58 PM
09/21/18 01:58 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Might be me you're talking about.
I made some a few years ago - needed one for my 440 and it worked fine, so I made a few extra in case anyone here wanted one. Same thing with valve cover spacers. All were aluminum, cut by water-jet. The starter adapter keyes off the block/trans locating pin.
But I couldn't sell enough of that stuff to keep doing it.
I think I have one left. Or, I can draw the pattern for you & mail it out.
Re: Who made the starter mounting brackets? [Re: ZIPPY] #2552857
09/21/18 02:10 PM
09/21/18 02:10 PM
Bowling Green, KY
cudaboy Offline
cudaboy  Offline
Bowling Green, KY
A quick search turned up a few old threads about this. This item was linked in one of them.
https://www.ebay.com/itm/383-440-MOPAR-Engine-Starter-plate-/301973329352
Dennis
Re: Who made the starter mounting brackets? [Re: ZIPPY] #2552870
09/21/18 02:38 PM
09/21/18 02:38 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
That's not the one I made, mine was much smaller, nothing surrounding starter.
Re: Who made the starter mounting brackets? [Re: ZIPPY] #2553020
09/21/18 08:11 PM
09/21/18 08:11 PM
S.E. Michigan
ZIPPY Offline OP
ZIPPY  Offline OP
S.E. Michigan
Okay thanks, they're out there then.
I dont have a flywheel handy so maybe I'll stick with using a core trans with an old converter.
Just trying to come up with ways to simply this for next time.
Rich H.
Esse Quam Videri
Re: Who made the starter mounting brackets? [Re: bonefish] #2553028
09/21/18 08:24 PM
09/21/18 08:24 PM
s.w.fl
bonefish Offline
bonefish  Offline
s.w.fl
SORRY iwas thinkin of sumpthin else.the starter bracket i bought works.i been tryin to download pic for ya but my e-mail aint playin nice.
Re: Who made the starter mounting brackets? [Re: bonefish] #2553040
09/21/18 08:46 PM
09/21/18 08:46 PM
s.w.fl
bonefish Offline
bonefish  Offline
s.w.fl
pic, sorry for the quality i had someone else do it.
Re: Who made the starter mounting brackets? [Re: ZIPPY] #2553108
09/21/18 11:40 PM
09/21/18 11:40 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Yup, that's one I made, or an exact twin.
Re: Who made the starter mounting brackets? [Re: topside] #2553199
09/22/18 12:06 PM
09/22/18 12:06 PM
moparx  Offline
when using a converter [for the starter ring gear] on a test stand, is it a better idea to cut the converter and remove the guts, just leaving the pilot face and ring gear ?
Re: Who made the starter mounting brackets? [Re: moparx] #2553226
09/22/18 01:28 PM
09/22/18 01:28 PM
s.w.fl
bonefish Offline
bonefish  Offline
s.w.fl
iagreethey shake pretty good without pump shaft support.
