Re: Rear end gears
[Re: 70charger512]
#2551505
09/18/18 02:17 PM
09/18/18 02:17 PM
Posts: 2,252 IL
furious70
IL
As the owner of a car with a cammed 440 and a .68 OD ratio with a 4.10 dana, my perspective is I still don't have enough gear to make effective use of OD until I'm going 70mph. Of course it screams in 4th gear at 65. The tremec gear splits don't work great with cammed up street cars IMO, 1st gear is already granny gear, if I put any more gear in it I'd never use first, less gear and I'd only use OD when I can go 80 on the freeway. If you go with a 3.55 I don't think you'd often find yourself in 5th gear.
Re: Rear end gears
[Re: 70charger512]
#2551729
09/18/18 11:44 PM
09/18/18 11:44 PM
Posts: 953 Chicago
PurpleBeeper
Chicago
Furious is giving you some really good advice. No overdrive, then 3.55's or 3.23's. With overdrive, 3.73, 3.91 or 4.10
440+6, NOS, 4-spd, SS springs
Re: Rear end gears
[Re: 70charger512]
#2551881
09/19/18 11:48 AM
09/19/18 11:48 AM
Posts: 2,252 IL
furious70
IL
I should have said I've got 28" tires. A 5.7 hemi is going to feel very different about the 'lugging' rpm, the heads are far more efficient than the old stuff.
