Re: RacePak user???
[Re: SCDaytona]
#2551064
09/17/18 02:12 PM
09/17/18 02:12 PM
Posts: 20,158 PA.
pittsburghracer
Just sent mine in for backlight issue and I was told $60 plus shipping. Should be back this week. M For that I would consider it. I kinda like to tinker so not sure which way I will go. Kinda hate paying twice
Re: RacePak user???
[Re: SCDaytona]
#2551207
09/17/18 07:06 PM
09/17/18 07:06 PM
Posts: 20,158 PA.
pittsburghracer
I was just called and it is confirmed. $65 to repair. Having it sent back 2nd day for $20. They received it Wednesday of last week. Here’s another issue I ran into once. I raced in the No Box Bonaza at Norwalk a few years ago and if you closely read the rules it says no data recorders. When I told him my RacePak dash was hooked to my data recorder it was needed to see my oil pressure, water temps, and other required info. He said I could not run the race. After some more calls I was told to remove the sd card and put a wire tie around it that could be inspected at any time. Gauges for me for now on.
Re: RacePak user???
[Re: SCDaytona]
#2551209
09/17/18 07:08 PM
09/17/18 07:08 PM
Posts: 20,158 PA.
pittsburghracer
I was just called and it is confirmed. $65 to repair. Having it sent back 2nd day for $20. They received it Wednesday of last week. Oh and I won’t pay them 85.00 to repair their junk. It should have been covered for the period I had it. I’ll fix it.
Re: RacePak user???
[Re: pittsburghracer]
#2551246
09/17/18 08:36 PM
09/17/18 08:36 PM
Posts: 1,454 Glendora Ca.
Just-a-dart
Glendora Ca.
That rule kept me from using a Racepak. New for 2018 data recorders are now legal in Pro et.
copied from et section COMPUTER Prohibited. See General Regulations 9:1. DATA RECORDER Data recorders are permitted in Advanced E.T., Super Pro, and Pro only. Data recorders (except for “playback”-type tachometers) are prohibited in all other E.T. classes. See General Regulations 9:2.
Re: RacePak user???
[Re: JERICOGTX]
#2551556
09/18/18 03:57 PM
09/18/18 03:57 PM
Posts: 19,360 Las Vegas
Al_Alguire
Las Vegas
IMO it depends on your goals and what you are trying to accomplish. For the bracket guy Oil press, fuel press, trans temp, water temp and vacuum would be all I would be concerned with. It comes with the G meters and voltage and driveshaft RPM. IMO driveshaft ROM and G meter will tell you a TON about how the car is working. Many people overlook the G meter and wheelspeed early in the run, it is the difference between and great running car and an average running one. As for engine vitals, engine vacuum will be your best friend here as far as ring seal and overall engine health. Oil pressure is nice the rest just seem to be stuff people want to see.
As for me I have a ton, never a thing as to much info...
Re: RacePak user???
[Re: JERICOGTX]
#2564614
10/15/18 10:09 PM
10/15/18 10:09 PM
Posts: 10,020 MN
JERICOGTX
MN
For those running a Dana 60, how did you mount your drive shaft sensor?
69 GTX
68 Road Runner
Re: RacePak user???
[Re: JERICOGTX]
#2564650
10/15/18 11:30 PM
10/15/18 11:30 PM
Posts: 8,021 Tulsa OK
Bad340fish
Tulsa OK
For those running a Dana 60, how did you mount your drive shaft sensor? I mounted mine to read the wheel studs, I am not sure if the racepak can give readings for this but my EFI can. Its just OK I liked it better when I had a sensor on the yoke with my 8.75 and I will be trying to do this for my Dana in the future. My moser yoke for my 8.75 had a provision for a sensor ring, the moser yoke for my Dana did not, that is what you get for assuming lol.
68 Barracuda Formula S 340
Re: RacePak user???
[Re: Bad340fish]
#2564739
10/16/18 09:02 AM
10/16/18 09:02 AM
Posts: 10,020 MN
JERICOGTX
MN
I have a Mark Williams yoke on my Dana 60 right now, but it doesn't have room for a ring. The Strange Billet yoke does, and I'll be going with one of those. Wonder if drilling and tapping a couple 1/4-20 holes in the case would be OK?
69 GTX
68 Road Runner
Re: RacePak user???
[Re: JERICOGTX]
#2564744
10/16/18 09:52 AM
10/16/18 09:52 AM
Bad340fish
Tulsa OK
I can't remember if there is room to do something like this on the Dana. I really want to change, haven't been real happy with the wheel stud reading because it has a blip in it likely from one of the studs being farther away than the others. The moser 5/8 studs aren't real consistent on the back side.
This is the motion race works kit for a ford 8.8
