Head Gasket leaking oil?
#2550395
09/15/18 07:03 PM
09/15/18 07:03 PM
Posts: 1,468 N.Y.
sixpacksteve
N.Y.
my 78 dodge van slant 6 is leaking oil in rear of pass side head. my friend said Bars leak might help. any truth to this or any other fix besides changing head gasket?
Hell Hath No Fury Like Mine
Re: Head Gasket leaking oil?
[Re: Porter67]
#2550497
09/16/18 12:34 AM
09/16/18 12:34 AM
for sure pin it down & a HG would necessitate a R&R.
[Re: sixpacksteve]
#2550764
09/16/18 08:56 PM
09/16/18 08:56 PM
Posts: 5,788 Hamilton, Ontario Canada
Magnum
It may not be the headgasket Steve. More likely it is the rocker cover gasket. Clean the area up and check it closely. Pretty easy job in a van.
As for your friend. I wouldn't call him an idiot like ^ but no chemical additive will out perform new seal or gasket.
I'd save Bar's leak for I'm stuck in the desert with x amount of water and I have a radiator leak and don't want to die out here.
[Re: 1E2C]
#2551283
09/17/18 10:09 PM
09/17/18 10:09 PM
Posts: 1,468 N.Y.
sixpacksteve
N.Y.
i will clean it, and check before changing head gasket. and hoping you guys are right!
[Re: sixpacksteve]
#2551296
09/17/18 10:43 PM
09/17/18 10:43 PM
Posts: 953 Chicago
PurpleBeeper
Chicago
Yep, get it SUPER DUPER clean using engine degreaser and your local car wash you spray yourself. Once, it's clean, drive it for a day and the oil leak will be obvious. I'm betting a valve cover gasket...but check.
440+6, NOS, 4-spd, SS springs
