How to hook up this pressure switch mpl-808
#2550173
09/15/18 01:41 AM
09/15/18 01:41 AM
Posts: 2,252 IL
furious70
IL
https://lh3.googleusercontent.com/NJx8_D...6I=w443-h910-noThe electrical hookup, 3 connectors on it, what goes to what? Their engineering diagram doesn't talk about the electrical connectors
Re: How to hook up this pressure switch mpl-808
[Re: furious70]
#2550299
09/15/18 01:41 PM
09/15/18 01:41 PM
Posts: 25,618 Rio Linda, CA
John_Kunkel
Can't open your link but the 3 connectors are usually *Normally Open, *Normally Closed and *Common.
[Re: furious70]
#2550311
09/15/18 02:11 PM
09/15/18 02:11 PM
Posts: 2,252 IL
furious70
IL
Makes sense but I can't see any marking on them to know which is which, will just have to try I guess
[Re: furious70]
#2550345
09/15/18 04:39 PM
09/15/18 04:39 PM
John_Kunkel
Use a multi-meter or test light to check for continuity between two terminals without vacuum and then with vacuum; one terminal will be common to both.
