Re: Torque Spec for Bango Bolts [Re: John_Kunkel] #2550975
09/17/18 11:34 AM
09/17/18 11:34 AM
Supercuda Offline
Supercuda  Offline
Originally Posted By John_Kunkel
Originally Posted By NANKET
Yes resistant to swelling and deterioration from oil, fuel, coolant, fire, etc, etc.
Please be wary of ANY product recommendations you see on these forums, folks. There is a reason auto manufactures don't use rubber to seal brake line fittings.
Oh, and what's the reason?
Because they have qualified engineers and not some internet clown making the decisions. BTW, they still use copper washers for this application, because they work and they do not deteriorate.
Go look up the 2018 Hellcat application. Copper sealing washers.
If you can't get them to seal quit buying cheap assed parts. Get factory washers if you can't find anything else because if they had the failure rate you have with them they would have quit using them decades ago. The problem isn't the design, it's you.
Don't be the exception.
Re: Torque Spec for Bango Bolts [Re: RTSrunner] #2551012
09/17/18 12:36 PM
09/17/18 12:36 PM
moparx  Offline
Originally Posted By RTSrunner
The Harley's I work on use rubber/metal sealing washers unless it is an ABS brake model,then they are solid washers.
i thought harley's were supposed to leak ? something about "marking their territory" ? biggrin [and it's monday now]
Re: Torque Spec for Bango Bolts [Re: Supercuda] #2551097
09/17/18 03:29 PM
09/17/18 03:29 PM
John_Kunkel Offline
John_Kunkel  Offline
Gosh, Cuda, you seem to be upset. Was it something I said? grin
You might have followed the link posted above and you'd find lots of rubber seals for brake system fittings (including the Stat-O-Seals I alluded to) and engineers specify their use. Just because an OEM uses a particular part doesn't mean everything else is gonna fail and cause you to crash and burn. Lighten up dude. rolleyes
https://www.pegasusautoracing.com/group.asp?GroupID=PLUMSEAL
BTW, Stat-O-Seals are routinely used in aircraft hydraulic systems that exceed 3000 psi.
