440 truck guys n here please
#2549750
09/13/18 08:55 PM
09/13/18 08:55 PM
Posts: 10,178 Someplace you aren't
SomeCarGuy
I need to find out how long the dipstick should be. Mine reads way off for some reason. I either need to find a longer one, trim the tube, or given my lack of time, the right one to just put in and be done.
I want my fair share
Re: 440 truck guys n here please
[Re: SomeCarGuy]
#2549784
09/13/18 11:06 PM
09/13/18 11:06 PM
Posts: 16,803 Between Houston & Galveston TX
SattyNoCar
My until someone chimes in with a measurement. The tube itself is nothing special, just a length of hardline. If you know you have the correct amount of oil in it based on what you put in, you can make your own tube and adjust it (re:cut) to where the dipstick reads correct. I did this with a truck I dropped a 440 into using parts from a 400 (the tube went MIA during tear down in my case). Sorry, this was back in the '90's, truck is long gone.
John
[Re: SomeCarGuy]
#2549801
09/13/18 11:50 PM
09/13/18 11:50 PM
Posts: 4,889 Wills Point, Texas
Hugh Jorgan
Wills Point, Texas
The flat thin strip of the dip stick measures 32-1/2" long.
It might be from a van...maybe an ambulance.
[Re: SomeCarGuy]
#2549814
09/14/18 12:06 AM
09/14/18 12:06 AM
SomeCarGuy
Wow. Mine is like 25. No wonder. Thanks
Big time disappointment to find this out. Truck is all there and all factory. Except somehow the dipstick.
[Re: SomeCarGuy]
#2549911
09/14/18 11:43 AM
09/14/18 11:43 AM
Posts: 15,487 Florida
scratchnfotraction
I will check what I got on my 440
I got a new inverted flare steel tube stock and cut 1 flared end off.
bent it into the shape I needed copying the piece of old broken tube.
top of tube bolted to exhaust manifold, I removed the flat tab & welded it to the new tube after a mock up fitting and trimming the tube.
I have a 6 qrt pan so I dumped 5 qrts in/ran engine to fill filter/ trimmed tube to get dead on ADD mark (scratched up a mopar stick from something? to use) then added 6th qrt and was dead on the full mark.
best part was I could have moved the tube further away from header tubes but it went right into the stock location more or less so I went that way on it.
if you are using a car 440 with a truck pan be sure to plug the car oil tube hole in the block.
[Re: SomeCarGuy]
#2549949
09/14/18 01:22 PM
09/14/18 01:22 PM
Posts: 1,400 Trumbauersville PA
ric3xrt
Trumbauersville PA
25 is about right, My midnight truck has been off since it was new, always reads 2 quarts low 2 of my 77s are the same way I know one was like that from new the other has a repo pan in it.
Truth has no agenda, but those with an agenda make their own truth. Some of us are so open minded they only see their View
[Re: SomeCarGuy]
#2550016
09/14/18 04:24 PM
09/14/18 04:24 PM
SomeCarGuy
If mine read at all with 6 in it wouldn’t be an issue. I think I’ve found a dorman for a powerstroke that will work assuming it fits in the tube. If I can get a chance to pull one from my other truck and see. It’s a little older ford than the one I found that listing for.
[Re: SomeCarGuy]
#2551979
09/19/18 04:11 PM
09/19/18 04:11 PM
Posts: 12,493 Western Colorado High Desert
moparmarks
OK I have some dip sticks for BB trucks. All are 27-3/8" overall length. All have a white knob on the handle. I have an extra stick but not a tube if you are still needing one. Shoot me a PM.
72 Satellite Sebring Plus 440, 72 Dart 5.9 4-spd, 68 Valiant, 73 W200, 78 D100 sb, 78 D200, 98 DAKOTA, . Moparmarks Parts & Restorations Desert Mopar Metal Grand Jct. CO 970-261-7039 http://moparmark.com/motormangj@gmail.com
