Re: '67 440 lifters?
[Re: markrr]
#2547879
09/09/18 12:08 PM
09/09/18 12:08 PM
Posts: 14,479 So. Burlington, Vt.
As long as the lifters and pushrods are for the same year, it’s not a problem.
67 and earlier lifters need 67 and earlier pushrods. 68 and later lifters need 68 and later pushrods.
[Re: markrr]
#2548208
09/10/18 01:26 AM
09/10/18 01:26 AM
Posts: 43,007 Bend,OR USA
Do you want stock size and type replacement pushrods or better after market ones? I may have enough of the originals ones for complete set If you want better than stock I am a dealer for Manton and they will make what ever you want that will be a lot stronger and stiffer than the stock OEM ones are. PM me on here if you want help on this
[Re: dogdays]
#2548389
09/10/18 02:16 PM
09/10/18 02:16 PM
Posts: 4,267 Morrow, OH
markz528
Morrow, OH
It isn't the pushrod that's 1/4", just the tip. You want the largest diameter pushrod that'll fit in your engine.
Actually if you're buying new pushrods I'd think seriously about changing to the later style lifters and pushrods.
R. Totally agree.
67 Coronet 500 9.610 @ 139.20 mph 67 Coronet 500 (street car) 14.82 @ 94 mph 69 GTX (clone) - build in progress......
[Re: markrr]
#2548460
09/10/18 05:06 PM
09/10/18 05:06 PM
Posts: 25,618 Rio Linda, CA
John_Kunkel
Custom pushrods can be made with a wide variety of ball sizes.
[Re: markrr]
#2548491
09/10/18 06:42 PM
09/10/18 06:42 PM
Actually if you're buying new pushrods I'd think seriously about changing to the later style lifters and pushrods. If you’re installing a new cam and lifters, that’s what I’d do.
