!964 Polara front bumper R&R #2546044
09/05/18 09:59 AM
09/05/18 09:59 AM
6T4 Polara Offline OP
New re chromed bumper to install on my Polara.
Have to remove existing bumper and install new.
What is the best way to do it,can I just remove bumper bolts?
Or do I have to remove the brackets mounted to the frame.
This is on your back work by a senior citizen with some help.
Re: !964 Polara front bumper R&R [Re: 6T4 Polara] #2546055
09/05/18 10:28 AM
09/05/18 10:28 AM
Pgh, PA
Bull1tt Offline
Bull1tt  Offline
Pgh, PA
I would unplug the lights and unbolt the brackets to remove bumper. Then you can get to all the bolts
Re: !964 Polara front bumper R&R [Re: Bull1tt] #2546057
09/05/18 10:40 AM
09/05/18 10:40 AM
moparx  Offline
as said, remove the bolts from the brackets bolted to the front rails after unplugging the park lights, then remove the whole assembly. it is good you have an assistant. they can help prevent any scratches or dings in the removal/installation process as well as being a second set of eyes when setting the new bumper to proper clearance and leveling from side to side. another thing to consider. don't "crank up" the bumper bolts too tight, as i have seen this cause depressions to appear around the bolts, as well as sometimes this causing the chrome to crack there as well.
Re: !964 Polara front bumper R&R [Re: 6T4 Polara] #2546082
09/05/18 11:33 AM
09/05/18 11:33 AM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
If like here better soak the bolts real good.Typically they have been in for decades and rusty.One of the 65s I had I needed heat to remove a few.Luckily I have impacts.Rocky
Chrysler Firepower
Re: !964 Polara front bumper R&R [Re: therocks] #2550025
09/14/18 04:51 PM
09/14/18 04:51 PM
No way for a senior farmed the job out and well satisfied.
Thanks to all respondents.
