Re: Square back alternator issue
[Re: Pacnorthcuda]
#2539092
08/20/18 03:37 PM
08/20/18 03:37 PM
Posts: 25,743 Rio Linda, CA
John_Kunkel
The front bearing has a stamped steel retainer plate, the 3 fingers of the retainer clip into the front cover. If the retainer fingers aren't properly clipped into the cover, the rotor can drift for/aft.
[Re: Pacnorthcuda]
#2539180
08/20/18 06:12 PM
08/20/18 06:12 PM
John_Kunkel
I've never had the correct puller fail, works on P/S pulleys too.
[Re: Pacnorthcuda]
#2539183
08/20/18 06:16 PM
08/20/18 06:16 PM
Posts: 14,889 up yours
Supercuda
You can rent that puller from AZ. I typically use a hose clamp around the bottom of the jaws as close to the pulley as I can get and tighten the HC up as much as possible. Keeps the jaws from spreading and sliding off. https://store.alternatorparts.com/463500-bearing-retainer-chrysler.aspx
