New dash harness install ? #2538276
08/18/18 10:31 PM
08/18/18 10:31 PM
New Mexico
JMCFAN Offline OP
JMCFAN  Offline OP
New Mexico
Installing new dash harness in 70RR... rally dash.. the fuse box on new one does not have acc attachembt where my air grabber and map light was attached,,,??
68 Charger 383/ AT Green/Green VT
70 Roadrunner 383/4sp Purple/Black VT
Re: New dash harness install ? [Re: JMCFAN] #2538279
08/18/18 10:47 PM
08/18/18 10:47 PM
Morristown Tn.
71birdJ68 Offline
71birdJ68  Offline
Morristown Tn.
Where did you get it? Have you called them?
Re: New dash harness install ? [Re: JMCFAN] #2538288
08/18/18 11:02 PM
08/18/18 11:02 PM
cbusters Offline
cbusters  Offline
The terminal is removable. I squeeze the fuse side together and it will push through.
Re: New dash harness install ? [Re: cbusters] #2538290
08/18/18 11:04 PM
08/18/18 11:04 PM
New Mexico
JMCFAN Offline OP
JMCFAN  Offline OP
New Mexico
Good to hear... was going to try... didnt want to break it...
Re: New dash harness install ? [Re: JMCFAN] #2538394
08/19/18 01:37 AM
08/19/18 01:37 AM
Why not reuse the original fuse box work twocents
Re: New dash harness install ? [Re: JMCFAN] #2538462
08/19/18 10:06 AM
08/19/18 10:06 AM
cbusters Offline
cbusters  Offline
When you had to restore your own dash harness, before the repop market had them, I had to strip down 4 harnesses and swap wires to get one harness together. The radio plug was the hardest to find. I had to turn a non a/c box into an a/c fuse box. I had to add missing wires.
Re: New dash harness install ? [Re: JMCFAN] #2538472
08/19/18 11:14 AM
08/19/18 11:14 AM
PA
70HemiGTX Offline
70HemiGTX  Offline
PA
M&H harness??? I have a new one also. I had to pirate a terminal from another old harness to fill the void. You would think they would put everything in that is supposed to be there....
Re: New dash harness install ? [Re: 70HemiGTX] #2538487
08/19/18 11:50 AM
08/19/18 11:50 AM
New Mexico
JMCFAN Offline OP
JMCFAN  Offline OP
New Mexico
Yea M&H.... from YO
Re: New dash harness install ? [Re: 70HemiGTX] #2538534
08/19/18 01:33 PM
08/19/18 01:33 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
The harness is basically for a 70 Charger, it adapts well for 90% of the 70 Plymouth/Dodge B body applications, odd ball options requiring electrical service have to be added with additional harness supplements, or removed from the existing harness, or fabricated...sure beats the old days when you needed to raid junk yards/parts cars for a hopefully complete harness
The only addition to my M&H harness I had to buy for my 70 Charger application was the Tach harness, other than that pretty much everything had service
FYI: I hope the OP took the time to compare the FSM wiring diagram and existing harness to the new one?, as well as check continuity of each circuit? much easier to troubleshoot the harness out of the car/dash before install... some (very few) have had problems with loose/poor crimped connection, or breaks in circuits
Mike
Re: New dash harness install ? [Re: DAYCLONA] #2539744
08/21/18 07:24 PM
08/21/18 07:24 PM
PA
70HemiGTX Offline
70HemiGTX  Offline
PA
Mike
I don't want to hi-jack the thread, but how well does the 5 gang straight terminal for the gauges fit on the pins? I just went to plug mine in and it falls off. I don't know what M&H calls the terminals they used in that plug, but they suck. They should have used female "bullet" type connectors. What M&H used was a terminal that has two flimsy prongs to make contact with the pins. Real impressive part. I will post some pics of them when I get back in my garage. I'm going to try and reuse the female ends from an old harness or find new ones somewhere.
