WHICH PLUG WHERE? #2537660
08/17/18 02:40 PM
08/17/18 02:40 PM
S.E.Ohio
Magnumguy Offline OP
S.E.Ohio
Found an NOS bigblock wire set, not I noticed some plug ends are 45deg angled, some are 90deg angled. Anyone know which ones go where?
"Multiple Magnum owner since 1978!!"
https://www.facebook.com/groups/146952895354657/
Re: WHICH PLUG WHERE? [Re: Magnumguy] #2537686
08/17/18 03:26 PM
08/17/18 03:26 PM
Chicago
PurpleBeeper Offline
Chicago
Geez, don't know. Maybe look for some pictures of factory restored engines online? You could probably narrow it down by the length of the wires too. I mean, a 1" long wire, regardless of plug end, doesn't go to cylinder #7. Sorry I'm not more help.
70 Roadrunner convt. street car 440+6, NOS, 4-spd, SS springs '96 Mustang GT convt. street car '04 4.6 SOHC, NOS, auto, lowered "Officer, that button is for short on-ramps"
Re: WHICH PLUG WHERE? [Re: Magnumguy] #2537787
08/17/18 06:47 PM
08/17/18 06:47 PM
S.E.Ohio
S.E.Ohio
Interesting answer, didn't think about that!
Re: WHICH PLUG WHERE? [Re: Magnumguy] #2538337
08/19/18 12:29 AM
08/19/18 12:29 AM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
You determine where they go by the length of the wires
#7 is the longest
#2 the shortest
you work your way from there
Re: WHICH PLUG WHERE? [Re: Magnumguy] #2538392
08/19/18 01:35 AM
08/19/18 01:35 AM
it probably depends on which year engine and body model the wire set is for work scope up
Re: WHICH PLUG WHERE? [Re: Magnumguy] #2538554
08/19/18 02:19 PM
08/19/18 02:19 PM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
If my memory is correct (and maybe not) all 67 and later with HP manifolds had 90* boots.
Re: WHICH PLUG WHERE? [Re: Magnumguy] #2538559
08/19/18 02:29 PM
08/19/18 02:29 PM
Nebraska
4406bbl Offline
4406bbl  Offline
Nebraska
If they are the orange ones from the 70s pretty sure #7 and 8 are 45, they were on the 2 of the 4 rear plugs on late 440. The problem with those wires is they were a little longer than stock so may need to use your judgement a little, at least mine were, date coded 1979.
