bolt in rear 4 link 69 dodge charger #2536821
08/15/18 05:16 PM
08/15/18 05:16 PM
Toronto,Canada
W
wkeggenhoff Offline OP
W
Toronto,Canada
Looking at installing a 4 link. Bolt in.
Looking at Qa1, Gerst, RMS, etc
Triangulated vs straight 4 link ? pros and cons of each ?
All seem to be in same price range.
Street car with 528 and 5spd. want a nice ride so any shock recommendations ?
Wont see any track use ?
69 dodge charger,528 Hemi,Keisler TKO 5spd, Mosier 60 rear end
Re: bolt in rear 4 link 69 dodge charger [Re: wkeggenhoff] #2536946
08/15/18 11:02 PM
08/15/18 11:02 PM
Bitopia
jcc Offline
jcc  Offline
Bitopia
ugh!
Next question, why?
Ever visit a Mustang forum and hear all the relentless complaining about their decades old triangulated 4 links? bump
Re: bolt in rear 4 link 69 dodge charger [Re: wkeggenhoff] #2537149
08/16/18 01:34 PM
08/16/18 01:34 PM
Mountain View, CA
68rrunner Offline
68rrunner  Offline
Mountain View, CA
None of the current offerings have very good specs.
Will the bolt in? Yes
Will they hold the back of the car up? Yes
Will they have a very limited range of motion and cause the car to shove in every corner like a plow? Absolutely.
Re: bolt in rear 4 link 69 dodge charger [Re: wkeggenhoff] #2537484
08/17/18 03:15 AM
08/17/18 03:15 AM
AndyF Offline
AndyF  Offline
I think I know what you're trying to do but not so sure you'll be happy. You'll need to post a bunch more information before you'll get any specific help.
If you want a nice ride and you won't be doing any track time then you might want to stay with a stock type suspension. Big rubber bushings and high quality shocks should give you what you want. Maybe add a stock anti-roll bar with rubber bushings for some extra control.
Re: bolt in rear 4 link 69 dodge charger [Re: wkeggenhoff] #2538018
08/18/18 08:14 AM
08/18/18 08:14 AM
The Netherlands
BigBlockMopar Offline
The Netherlands
I agree you'll probably have more bang for your buck if you spend (some of) the money on your stock suspension.
The engineers at the factory were experts at making suspensions that drove and handled nice. Just read all the magazine roadtests of the era, comparing them to GM's and Ford's offerings.
Re: bolt in rear 4 link 69 dodge charger [Re: BigBlockMopar] #2538131
08/18/18 02:09 PM
08/18/18 02:09 PM
Colorado
Bob J Offline
Bob J  Offline
Colorado
Our cars may have out handled a Ford or Chevy at the time but a modern minivan will out handle it today. So upgrading is the thing to do. That being said I went with the Hotchkis TVS system as it looked like balanced system that will work together. and lots of bracing and welding of seams.
If I upgrade at a later date I would look at the Magnum Force rear suspension but it is weld in. It will also give you more tire clearance.
07 Porsche C2 997.1 6spd DD and SCCA Solo II SS
68 Plymouth GTX Convert. 493cu Hotkiss Wilwood Classic air, Building for Solo II Cam
65 Chrysler 300 Convert. project
57 Desoto 2dr. Firesweep 392 Hemi,Wilwood Project with son
2003 Dodge Dakota R/T "DEAD"
Re: bolt in rear 4 link 69 dodge charger [Re: wkeggenhoff] #2538135
08/18/18 02:15 PM
08/18/18 02:15 PM
Supercuda Offline
Supercuda  Offline
there isn't a bolt in 4 link for our rides that will outhandle updated stock.
Or stock for that matter
Don't be the exception.
Re: bolt in rear 4 link 69 dodge charger [Re: Supercuda] #2538179
08/18/18 04:46 PM
08/18/18 04:46 PM
Mountain View, CA
68rrunner Offline
68rrunner  Offline
Mountain View, CA
Bingo. I set up a Cuda with RMS front and Ridetech rear to the best of my abilities for a customer. The car handled well; but I let the owner take EMax (Full Hotchkis Equipped Challenger) out for a spin. He came back and said: "Wow. I could have saved a lot and time, money and effort If I had just stuck with Torsion Bars and Leafs"
I'm not going to say what is wrong with the other coilover and link systems since I'm not paid to help them out; but I will say that the geometry is less than ideal in any situation where the car is not moving in a straight line.
If the market would support it; a quality coil system could and would be developed; however it would not be a bolt on solution and would require several compromises to the chassis that most folks aren't willing to do with a moderate level of fabrication work. I'd do it to a Satellite or some other car but I'm not sure I'd be up for doing it to a car I cared about like my Road Runner; but I'm getting tempted on this go around and we've drafted up some really killer setups.
Re: bolt in rear 4 link 69 dodge charger [Re: wkeggenhoff] #2553941
09/24/18 02:19 AM
09/24/18 02:19 AM
Seattle WA
RichV Offline
RichV  Offline
Seattle WA
The only good 4 link suspension has 3 longitudinal links and a panhard bar. In the mid 90s when I was working for Delphi Chassis, the suspension engineers did not like the four link rear suspensions that where on the last generation Caprice, these where the guys that had to make this suspension work.
Re: bolt in rear 4 link 69 dodge charger [Re: RichV] #2554233
09/24/18 09:04 PM
09/24/18 09:04 PM
Supercuda Offline
Supercuda  Offline
Sounds like you are talking about a torque arm suspension.
Re: bolt in rear 4 link 69 dodge charger [Re: Supercuda] #2554387
09/25/18 10:35 AM
09/25/18 10:35 AM
moparx  Offline
i only have a passing knowledge of the torque arm setup, but is/would there be any appreciable amount of binding if the front mount is too far from the u-joint pivot point ?
Re: bolt in rear 4 link 69 dodge charger [Re: moparx] #2554419
09/25/18 11:56 AM
09/25/18 11:56 AM
Bitopia
jcc Offline
jcc  Offline
Bitopia
No, remember both of these joints are normally a slip design, only one is required to prevent bind. This assumes a perfect no friction slip.
A torque arm style is not in my mind what one considers when talking 3 links fwiw, but if you does not want to extension floor modifications and/or requires a back seat, its a well accepted productive design.
Re: bolt in rear 4 link 69 dodge charger [Re: wkeggenhoff] #2554656
09/25/18 06:44 PM
09/25/18 06:44 PM
Supercuda Offline
Supercuda  Offline
Look at the line drawing I posted, there is no slip joint for the torque arm.
You want both the pivot and the U joint to be as close to in line as possible. The point of the torque arm is to control axle wrap.
If there is a bit of movement the slip yoke in the driveshaft handles it.
Re: bolt in rear 4 link 69 dodge charger [Re: Supercuda] #2554689
09/25/18 07:37 PM
09/25/18 07:37 PM
Bitopia
jcc Offline
jcc  Offline
Bitopia
Lot to unpack here.
I guess the first clarification is a "slip" joint in this context means a joint/connection with enough play to handle some of the kinematics involved here, as there is no need for constraint of the torque in more then one axis.
I am not sure that in every case both the u joint and torgue arm chassis connection need to be oriented close, as that location plays a part in deciding the desired instant center.
And everyone should remember "axle wrap" also includes braking forces.
It is possible to use another separate above the axle arm for braking forces only, and then decouple the torque arm discussed here in this scenario, but this is getting above my pay grade. biggrin
Re: bolt in rear 4 link 69 dodge charger [Re: wkeggenhoff] #2554718
09/25/18 08:57 PM
09/25/18 08:57 PM
Supercuda Offline
Supercuda  Offline
“If you can't explain it to a six year old, you don't understand it yourself.” ― Albert Einstein
Try it without the thesaurus.
OEM torque arm suspensions, much like OEM triangulated 4 links, use large bushings for NVH. That's noise, vibration and harshness.
In a handling setup, this is the handling forum isn't it, NVH is irrelevant. You'd use delrin for the bushing to minimise unwanted movement. To further minimize unwanted movement, the u joint and the pivot need to line up.
Do some research on torque arm suspensions.
Re: bolt in rear 4 link 69 dodge charger [Re: Supercuda] #2554760
09/25/18 10:12 PM
09/25/18 10:12 PM
Bitopia
jcc Offline
jcc  Offline
Bitopia
We disagree.
Re: bolt in rear 4 link 69 dodge charger [Re: Supercuda] #2555381
09/27/18 03:35 AM
09/27/18 03:35 AM
Seattle WA
RichV Offline
RichV  Offline
Seattle WA
A three link and a torque arm are different designs. The torque arm constrains the arm to the rear end in rotation. The three link has three longitudinal links that can use sperical joints on each end. See the following link for pictures. The general layout has two lower links outboard. The single upper link can be located in the middle or on either side.
http://www.chassisunlimited.com/product/link-suspension-kits/3-link-suspension-kit-e.html
Re: bolt in rear 4 link 69 dodge charger [Re: RichV] #2555580
09/27/18 03:25 PM
09/27/18 03:25 PM
Bitopia
jcc Offline
jcc  Offline
Bitopia
We agree.
On a further note, the location of the upper 3rd link off center, has useful bearing on the end result handling characteristics, ie its location is not random.
Re: bolt in rear 4 link 69 dodge charger [Re: wkeggenhoff] #2556008
09/28/18 03:12 PM
09/28/18 03:12 PM
Pikes Peak Country
TC@HP2 Offline
TC@HP2  Offline
Pikes Peak Country
Interesting read on a 3 link vs torque arm set up, in a mustang application, of course.
https://trackmustangsonline.com/threads/torque-arm-vs-3-link-imho.13639/
Re: bolt in rear 4 link 69 dodge charger [Re: TC@HP2] #2556021
09/28/18 04:02 PM
09/28/18 04:02 PM
Bitopia
jcc Offline
jcc  Offline
Bitopia
Interesting read, but not sure we are comparing apples to apples here, since the geometry is likely vastly different between the two set-ups, beyond just the hardware, and the 3 link might just be a better tune for this application, which also means it could be tuned for a much worse result. Also over my pay grade, but I suspect the real three link normally has a lot wider tune window then the TA set-up, if for any no other reason, then just space for adjustablity.
