Re: calculating peak rpm hp
[Re: B3422W5]
#2536864
08/15/18 07:31 PM
08/15/18 07:31 PM
Posts: 20,116 PA.
pittsburghracer
For sure, but thought i might try short shifting at 6000 to start. Then 6500 and go from there. Any such way like that will ultimately find out what i likes best. Love ya man, but frankly you make things more involved and harder than anybody that has ever posted on here... lol WOW 😮. That wasn’t a very cool thing to post. LOL.
[Re: mopar dave]
#2536868
08/15/18 07:36 PM
08/15/18 07:36 PM
Posts: 2,457 Sydney,Australia
tex013
Sydney,Australia
nothing wrong with checking others opinion/experience , if only to confirm you are heading in the right direction .
Tex
[Re: mopar dave]
#2537050
08/16/18 08:55 AM
08/16/18 08:55 AM
sgcuda
Ask any questions you like. That's how we all learn. There are never stupid questions, only stupid people. Lol! Some people on here make comments about the repetition of questions. Sometimes we forget that people come and go off of this site all of the time. What people need answers to aren't in the first couple of pages listed and we all know too well how wonderful the SEARCH function works on here. My old combo with a 262/266 lift on my 440 liked a 6,800 rpm shift point. Car would slow down with a 6,500 or 7,000 shift. You'll find the sweet spot real quick.
[Re: mopar dave]
#2537060
08/16/18 09:57 AM
08/16/18 09:57 AM
Posts: 4,457 Washington
madscientist
Washington
FWIW once you establish your shift speed, you may want to try changing RPM for just one gear. For example, you may be able to run the 2-3 shift out a bit more than the 1-2 shift. Or it could be the opposite. It's not always that the engine wants to be shifted at the same RPM at every shift change.
[Re: mopar dave]
#2537104
08/16/18 12:02 PM
08/16/18 12:02 PM
Posts: 4,205 New York
polyspheric
This^^^ All modern transmission have "ratio progression" in which the RPM % drop on shift is widest on the 1-2, and closes up as you reach final drive.
Boffin Emeritus
[Re: madscientist]
#2537220
08/16/18 03:36 PM
08/16/18 03:36 PM
BradH
FWIW once you establish your shift speed, you may want to try changing RPM for just one gear. For example, you may be able to run the 2-3 shift out a bit more than the 1-2 shift. Or it could be the opposite. It's not always that the engine wants to be shifted at the same RPM at every shift change. A couple of Stock Eliminator people I know shift their 1-2 200-300 RPM lower than their 2-3. Never tried it on my junk, simply cuz I position the tach "straight up" at the RPM where I shift for easy reference. Also, I don't use a shift light any more; I was always late on the shift when waiting for the light at the specified RPM. I'm more consistent w/ the approach above. Regardless, I was never aware of any major shift lag time that caused my actual shifts' RPMs to be so much higher like some of you said. I'd like some type of data logger or playback tach to see what's happening across the whole pass, though.
[Re: BradH]
#2537228
08/16/18 03:41 PM
08/16/18 03:41 PM
Posts: 20,116 PA.
pittsburghracer
A powerglide kinda simplifies this option
[Re: mopar dave]
#2537290
08/16/18 05:43 PM
08/16/18 05:43 PM
polyspheric
You may also see different converter slippage on different shifts: the 1-2 has more torque, but the 3-4 is against higher load. Once you find what works for you, the reason sort of matters less...
Boffin Emeritus
[Re: mopar dave]
#2537334
08/16/18 07:17 PM
08/16/18 07:17 PM
Posts: 7,471 Minnesota
Hemi_Joel
Minnesota
At the pure stock drags, where you weren't allowd to add a tach, they use to say "when the fender starts to lay down, SHIFT"
