Re: hemi rocker arm to retainer clearance.
[Re: johnzgarage]
#2535824
08/13/18 08:19 PM
08/13/18 08:19 PM
Posts: 4,785 Utah and Alaska
astjp2
Utah and Alaska
Have you checked the ratios? I would do that first, compare to your cam specs and then decide if they are worth grinding on. Mine were all over, wound up with StageV rollers and Dvorak stands that widen out the spread...Tim
1941 Taylorcraft 1968 Charger 1994 Wrangler 1998 Wrangler 2008 Kia Rio 2017 Jetta
[Re: johnzgarage]
#2535834
08/13/18 08:42 PM
08/13/18 08:42 PM
Posts: 7,471 Minnesota
Hemi_Joel
Minnesota
With stock rockers, I assume that the springs are not outrageously stiff. I've taken .040" But cutting anything at all weakens it, and increases the risk of failure.
[Re: johnzgarage]
#2535946
08/14/18 12:29 AM
08/14/18 12:29 AM
Posts: 3,097 back in Georgia
dthemi
back in Georgia
Are you using up retainers? Common to have .100 up retainers to gain install height. If you are, go to a standard, or down retainer. Obviously spring pressure will go up, and you'll need to check for bind, or retainer to guide clearance, but you can also usually cut the spring pocket deeper, and keep the same spring pressure with the retainer change. Lash caps, like mentioned can help your problem, but might make the geo, or starting position worse.
[Re: johnzgarage]
#2535996
08/14/18 02:38 AM
08/14/18 02:38 AM
hemi-itis
My last go round I ended up having to use a -50 thou retainer to gain the needed clearence,,,,,then had to buy new springs to go with the new titanium retainers. Thanks again Marsh Performance for your expert advise and quick delivery Had to take off them purty polished springs
[Re: Cab_Burge]
#2536058
08/14/18 10:14 AM
08/14/18 10:14 AM
an8sec70cuda
I used lash caps on mine when I mocked mine up for the first time and found the DLI roller rockers were hitting the titanium retainers. The caps got me the clearance I needed and have been in use since 2006 w/ no issues at all. I mention that b/c I've heard a lot of people question the durability of lash caps.
[Re: johnzgarage]
#2536096
08/14/18 11:51 AM
08/14/18 11:51 AM
Posts: 4,205 New York
polyspheric
If you geo is on target now, lash caps will ALWAYS make it worse. If it's not on target now, they may make it better or worse. Whatever you do to the lever's underside, blend the cut back into the body and polish it, leave no sharp edges.
Boffin Emeritus
