2002 Ram 3500 cummins no start? #2534881
08/12/18 01:04 AM
08/12/18 01:04 AM
Covington Georgia
RV2 Offline OP
RV2  Offline OP
Covington Georgia
I've been having an intermittent no start issue the past couple of months, engine turns over but no start, then it will start.
I bought the truck in 2010 with 100k on it and now it has 178k
I added an Airdog 150 fuel system back when I bought it.
I have 14 psi of fuel pressure
Tonight it would not start and I had to get towed home.
Any ideas?
Re: 2002 Ram 3500 cummins no start? [Re: RV2] #2535310
08/12/18 09:28 PM
08/12/18 09:28 PM
Covington Georgia
RV2 Offline OP
RV2  Offline OP
Covington Georgia
I think I found the problem, found a corroded terminal on the fuel pump relay.
Re: 2002 Ram 3500 cummins no start? [Re: RV2] #2551148
09/17/18 05:25 PM
09/17/18 05:25 PM
Calgary, Alberta Canada
a12rag Offline
a12rag  Offline
Yay . . . easy fix !!! Always check the easy stuff first !
