Re: Is there a good way to mount a starter into a Lakewood bell?
[Re: DusTed74]
#2533448
08/08/18 07:38 PM
08/08/18 07:38 PM
Posts: 30,994 Oregon
AndyF
The Lakewood bellhousing has been a piss poor design since day one and they have never fixed it. As pointed out above you need to match the nose cone location with your flywheel size. Lakewood has a cheesy adapter bracket that may or may not fit correctly. On my car I ended up taking the whole thing to a machine shop where they modified the bellhousing so it worked. Here is what mine looked like after we were done with it.
[Re: Stanton]
#2533449
08/08/18 07:39 PM
08/08/18 07:39 PM
Posts: 4,457 Washington
madscientist
Washington
Sounds like you need the adapter kit
Never heard of the adapter kit. New to me. I just swear a lot when I put my starter in. I swear at the starter, the headers, the scatter shield, the car, the weather, the dogs, the radio...and anything else I can think of and it just pops right in. Evidently, that junk doesn't like me swearing at it.
[Re: madscientist]
#2533452
08/08/18 07:46 PM
08/08/18 07:46 PM
Posts: 20,159 PA.
pittsburghracer
Never had starter issues with mine and my 1972 340 Duster and I even had the BIG starter back then. My big issue was getting it indicated in right. What a pain in the butt working on the ground on ramps.
[Re: DusTed74]
#2533492
08/08/18 09:37 PM
08/08/18 09:37 PM
Posts: 4,951 northwest USA
NANKET
northwest USA
This is for BB Lakewood scatter shield. I don't know what they do on a smallblock.
They have a bolt in cone that the starter snout pilots into. Two holes where this could go for each flywheel size. See Andy Fs picture, there is a bolt head facing the clutch fork with an empty hole next to it.
Then with the 130 tooth flywheel the top starter bolt goes through the scatter shield. But it doesn't use the lower bolt hole, it uses and adapter pin that bolts to the bellhousing lip and pilots into the lower starter mounting hole. Hoakey but it does work.
I needed these items and I had them copied and fabricated from the originals a guy had. I still have them someplace.
With the 143 tooth flywheel the starter bots directly the the scatter shield through the 2 bolt holes.
[Re: AndyF]
#2533524
08/08/18 11:16 PM
08/08/18 11:16 PM
madscientist
Washington
The Lakewood bellhousing has been a piss poor design since day one and they have never fixed it. As pointed out above you need to match the nose cone location with your flywheel size. Lakewood has a cheesy adapter bracket that may or may not fit correctly. On my car I ended up taking the whole thing to a machine shop where they modified the bellhousing so it worked. Here is what mine looked like after we were done with it. I doubt that would ever pass a new certification. Not a big deal if you run 11.50 or slower.
[Re: DusTed74]
#2533562
08/09/18 12:38 AM
08/09/18 12:38 AM
sgcuda
I have run Lakewood shields since the late 70's. No big deal. 143t flywheel bolts up direct. 130t flywheel, you need an adapter for the lower hole. I've used nothing more than 2 bolts and a piece of flat stock to make my own adapter. I've used a chopped off piece of 4 speed cluster shaft bearing spacer for the centering cone, with a flat washer and nut welded on the end, and then hand file the starter nose to fit. You guys need to get a grasp on fabricating for performance/racing. If you millennials want stuff to fit off the shelf, buy a Chevy.
[image][/image]
[Re: DusTed74]
#2534551
08/11/18 01:15 PM
08/11/18 01:15 PM
Posts: 21,065 Niles , Ohio
therocks
Niles , Ohio
Have a Lakewood in the 65.Starter fits good with the 143.I have an old Ansen in the garage that Ive thought about using.Dont know if it uses 130 or 143.Bought it for the block plate my Lakewood was missing.Rocky
Chrysler Firepower
