Re: 6 lug to 5 lug conversion on 97 dakota(front)
[Re: Don_440]
#2527639
07/26/18 10:44 PM
07/26/18 10:44 PM
Posts: 10,486 Freeport IL USA
poorboy
Freeport IL USA
I assume what you really want it the 5 on 4 1/2" bolt circle.
Maybe you can get the 5 bolt spindles by swapping everything between the ball joints, but I haven't done it, or even compared to see if the suspensions are even close to being the same. It might be cheaper to have the 6 bolt stuff re-drilled to the 5 bolt stuff, but I suspect there may be issues with some of the wheel stud holes since the 6 bolt stuff is also on a 4 1/2" circle. I think your opening up a can of worms, but if you succeed, please let us all know what you did, with the needed part numbers. I'm sure others will appreciate you venturing into this unknown area.
I would swap out the entire rear end for something with the correct bolt pattern, or buy aftermarket axles for your rear end, if you have a 9 1/4. I wouldn't bother with any smaller rear, just swap it out with something that has the bolt pattern you want. Gene
[Re: Don_440]
#2528364
07/28/18 06:48 PM
07/28/18 06:48 PM
Posts: 25,618 Rio Linda, CA
John_Kunkel
I have taken my stock front hubs to my machinist,ran in on cad said there is no way to convert bolt circle,unless you plug weld holes and redrill(not happening on cast hub liabity issues). Perhaps not plugged by welding, but the holes could be threaded and plugged to make a new surface to drill the five new stud holes. Labor intensive and expensive
[Re: Don_440]
#2528401
07/28/18 08:37 PM
07/28/18 08:37 PM
Posts: 1,189 Michigan
begood
Contact a company called 1320 Wheels, they can make up 5 lug hubs for the Dakota.
THERE IS NO SUCH THING, AS TOO MUCH HORSEPOWER
[Re: Don_440]
#2535841
08/13/18 08:54 PM
08/13/18 08:54 PM
Posts: 1,260 New Mexico
Adobedude
New Mexico
Moser plugged and drilled my front hubs.
2001 Dodge Dakota 408 All Motor 11.27 @ 117.83 mph 2017 NM Mopar Challenge Series Champion.
[Re: Don_440]
#2555605
09/27/18 05:16 PM
09/27/18 05:16 PM
Posts: 12,043 State of Confusion
hp383
Just a normal tag again
State of Confusion
Have you looked at using 2wd D150 rotors from about 1984
I know those fit the 91-96 first gen 6 lug spindles, since guys using the Dakota drop spindles on their trucks use them.
But I dont know about the 97
Join the Penguin Liberation Front!! Stop the Hippo Occupation!
