over pressure a/c situation: 2012 Dodge Ram 5.7
#2525568
07/22/18 09:44 PM
07/22/18 09:44 PM
Posts: 8,827 Houston, Tx
hemi68charger
Houston, Tx
Hey gang.. I think I over pressured my a/c system in my 2012 Dodge Ram.. It had never been serviced since new and thought it was not cooling as well as it used to be.. So, I bought one of those recharge cans with gauge and trigger... The next day, the a/c started not acting properly... I think I over pressured the system.. Isn't there a high-pressure cut-off sensor/valve in the system? If so, can I just release/extract some freon from the system? I think there's a valve at the bottom of the low-pressure side inlet valve?
Cheers,
TroyHouston Mopar Connection Club'69 Charger Daytona 440 - auto - 4.10 Dana (now with 426 hemi) '69 Charger 500 440 - 4speed - 3.54 Dana '70 Road Runner 383 - 4speed - a/c (now with 440)
Re: over pressure a/c situation: 2012 Dodge Ram 5.7
[Re: hemi68charger]
#2525744
07/23/18 09:11 AM
07/23/18 09:11 AM
Posts: 20,627 in a cattle trailer down by th...
Guitar Jones
Condenser fans are known to go out on those trucks. Have the system evacuated and recharged with the proper amount and check the fan operation.
[Re: gch]
#2535332
08/12/18 10:13 PM
08/12/18 10:13 PM
Posts: 28,312 Cincinnati, Ohio
Challenger 1
Cincinnati, Ohio
Hate the stuff in a can.ESPECIALLY if it has STOP LEAK in it. So true and I agree! If stop leak was used I won't use my AC recyler on your car because it mess up my machine and containment it. Those deals have messed up plenty of AC systems by misuse. Great money maker but not real accurate and can cause plenty of damage to AC system by over charging.
