Loading up and slight miss
#2525037
07/21/18 05:40 PM
07/21/18 05:40 PM
Posts: 1,548 Michigan
Kiddart
I am getting a load up type feel on my car and feels like a miss at idle and putting around in second gear. When I get on the loud peddle it smooths out and get to business. I went through and did plugs (gap at 40) new MSD wires new cap new rotor new pickup in distributer. lashed the valves at .020 cold(per Indy). As some may remember I have the Fast ez efi system. it ran great last summer now its a pile of poop.
Can a bad voltage regulator cause this?? that's about all I haven't replace.
be gentle I am ready to burn the car to the ground at this point.
Thank you Kiddart
Re: Loading up and slight miss
[Re: Kiddart]
#2525043
07/21/18 05:48 PM
07/21/18 05:48 PM
Posts: 3,831 N.E. Ohio
6bblFLASH
N.E. Ohio
Not an expert by any definition,,but how much fuel have you gone thru with this issue?
Funky load of pump gas,,it happens.???
Maybe some strong injector /fuel treatment might yield something.
Possibly temp. sensor issue. EFI thinks engine is cold/enrichment too??
70` Cuda`,440 6BBL Jerico,Dana 4.56 Still on 93 Pump Gas 9.87 @ 136/1.31-60ft.`09 Mopar Nationals PASSON PERFORMANCE "Stick-Shift" Champ! 2013 StickShift Challenge Winner@ Mopar Nationals!
[Re: Kiddart]
#2525047
07/21/18 05:59 PM
07/21/18 05:59 PM
Kiddart
I haven't gone thru to much fuel, the issue starts as soon as I crank it up within 5 seconds or so. I should try some injector cleaner as well
Thank you Kiddart
[Re: Kiddart]
#2525281
07/22/18 12:05 PM
07/22/18 12:05 PM
Kiddart
Racerhog, heads were just freshened at Modern cylinder head over the winter.
B1maxx I can check the O2 but not getting a error code?
Thank you Kiddart
[Re: Kiddart]
#2525472
07/22/18 06:27 PM
07/22/18 06:27 PM
Kiddart
I run the Turbo Blue from the pump, but didn't leave any in over the winter. I will get some injector cleaner and see what happens
Thank you Kiddart
[Re: Kiddart]
#2526315
07/24/18 11:51 AM
07/24/18 11:51 AM
Kiddart
Here is my course of action as of today. 1. I am taking out the injectors and have my son clean them and test them at school next week 2. Going to test and or replace O2 Sensor after the injectors are cleaned 3. New Plugs AGAIN before I restart it.
Not sure when all this will take place because I am nursing a rib injury and have my daughters grad party this weekend. I know its Monster Mopar at Norwalk, my wife didn't clear the date with me before planning the party. LOL
Its to hot to race anyways.
keep the comments and thoughts coming.
Thank you Kiddart
[Re: Kiddart]
#2530946
08/03/18 01:29 PM
08/03/18 01:29 PM
Kiddart
B1MAXX, Looks like its the o2, pulled it last night and its in really bad shape completely loaded up with carbon. I was playing with the AF settings and it wasn't taking any thing, I ordered a new one this morning from Jegs. See what happens when its gets here.
Thank you Kiddart
