Re: Gen3 vs Big Block - Mid-Plate to Front Motor Plate: Measured
[Re: moparmitch]
#2525300
07/22/18 12:47 PM
07/22/18 12:47 PM
Posts: 1,454 Glendora Ca.
Just-a-dart
Glendora Ca.
I bought a tube car that was a big block and the tabs on it worked out to be approximately 1/4" different then my gen3
[Re: Just-a-dart]
#2525669
07/23/18 12:43 AM
07/23/18 12:43 AM
Posts: 153 MI, USA
moparmitch
MI, USA
Thanks for sharing, thats two of us with similar numbers so far. Hopefully, more will chime in.
Did you remove the G3 water pump and put a motor plate against the front cover?
[Re: moparmitch]
#2525709
07/23/18 02:48 AM
07/23/18 02:48 AM
Just-a-dart
Glendora Ca.
Yes, I used a .090 steel mid plate(it was a 1/4" alum before) and a 3/8 front plate in the pump area tapped for water 3/4"npt in and 1"npt out.
Then attached 1/4" plates on each side to the front of it to attach to the orginal chassis tabs.
So my front plate is 3 parts. Making a 3/8" step forward
