Re: can a '67 440 Chrysler "300" have an AVS? [Re: RapidRobert] #2525034
07/21/18 05:29 PM
07/21/18 05:29 PM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
Just to toss out a complete guess, if it's an AVS I'd bet short odds that it's a 4966s which was a very commonly used as a "one size fits all" replacement.
Re: can a '67 440 Chrysler "300" have an AVS? [Re: RapidRobert] #2525048
07/21/18 06:04 PM
07/21/18 06:04 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
67 and 68 manifolds where the same casting number. There was a discussion on this in another post awhile back. Some AFBs had dual bolt patterns
Re: can a '67 440 Chrysler "300" have an AVS? [Re: RapidRobert] #2525107
07/21/18 09:42 PM
07/21/18 09:42 PM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
All 67s 440s used large bolt pattern, 350 used a Holley, 375 used large bolt pattern AFB.
Re: can a '67 440 Chrysler "300" have an AVS? [Re: ScottSmith_Harms] #2525197
07/22/18 01:54 AM
07/22/18 01:54 AM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
No no no.
That's a 71 440HP carb
GG says so hop
Re: can a '67 440 Chrysler "300" have an AVS? [Re: BSB67] #2525214
07/22/18 02:39 AM
07/22/18 02:39 AM
northwest USA
N
NANKET Offline
NANKET  Offline
N
northwest USA
Correct! All 440 engine 67-69 model years used the 2806178 intake manifold. Wide bolt pattern. We are talking M code 440 Cudas to grandmas town and county station wagon, to Mr. Drysdales Imperial convertible. Same intake manifold guys.
1966 and older RB intakes were narrow pattern, all 1967 and older 383's were narrow pattern.
So Morty the 1967 440 is the only AFB car that can take an AVS on the same intake.
Yes it can have an AVS but Chrysler didn't put it there. The 67 300 440 LP 350 horse engine came with a Holley and not very reliable. No surprise it was replaced with an AVS which is more common and with the air door adjustment its very easy to get them to run good.
I've never seen a 1967 car with an AVS from th factory. Look
at the parts book and shop manual, no AVS in there either.
The air cleaner base would have the large hole for AVS instead of small hole for AFB. But you can get the base or the entire air cleaner form the car that donated the AVS. Choke thermostat is different also. Fuel line the same.
Re: can a '67 440 Chrysler "300" have an AVS? [Re: NANKET] #2525221
07/22/18 03:21 AM
07/22/18 03:21 AM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
Correct! All 440 engine 67-69 model years used the 2780178 intake manifold. Wide bolt pattern. We are talking M code 440 Cudas to grandmas town and county station wagon, to Mr. Drysdales Imperial convertible. Same intake manifold guys.
Cool - learned something today up
Re: can a '67 440 Chrysler "300" have an AVS? [Re: RapidRobert] #2525252
07/22/18 10:44 AM
07/22/18 10:44 AM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
No no no.
GG says so
.....Yes,yes,yes, laugh , and it was commonly used as a one size fits all replacement, most I see are dated post 71 production, dated 1972,3,4, etc.
Re: can a '67 440 Chrysler "300" have an AVS? [Re: ScottSmith_Harms] #2525268
07/22/18 11:41 AM
07/22/18 11:41 AM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
No no no.
GG says so
yep - it's a parts carb
Re: can a '67 440 Chrysler "300" have an AVS? [Re: Morty426] #2525288
07/22/18 12:22 PM
07/22/18 12:22 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
And thank God there are so many out there, the pile I have hoarded up have saved many a rare list # carbs sorely needing parts.
Re: can a '67 440 Chrysler "300" have an AVS? [Re: ScottSmith_Harms] #2525845
07/23/18 01:27 PM
07/23/18 01:27 PM
RapidRobert Offline OP
the intake # is 2606178 & the date is 1-25-67. the AVS # is 4966 S CM23 on the drivers side inner fender bolt on tag
Re: can a '67 440 Chrysler "300" have an AVS? [Re: RapidRobert] #2525855
07/23/18 01:55 PM
07/23/18 01:55 PM
Buford, GA
I_bleed_MOPAR Offline
Buford, GA
Scott nailed it. up
Tim
'71 Charger 383/727
'17 Challenger SXT (Wifeys car wink )
Re: can a '67 440 Chrysler "300" have an AVS? [Re: RapidRobert] #2525862
07/23/18 02:19 PM
07/23/18 02:19 PM
God's Country Maryland
GODSCOUNTRY340 Offline
Chevy used an AVS in 1966 on their 327 275 HP engines, number 4028SA
Re: can a '67 440 Chrysler "300" have an AVS? [Re: I_bleed_MOPAR] #2525863
07/23/18 02:21 PM
07/23/18 02:21 PM
Didn't he though! The AC compressor was covering the pad I wanted to get a letter off of, but the eng sure does look OE/untouched.
Re: can a '67 440 Chrysler "300" have an AVS? [Re: RapidRobert] #2525893
07/23/18 03:33 PM
07/23/18 03:33 PM
dogdays Offline
dogdays  Offline
There's a zillion 4966S carbs floating around. One thing, they use a different diameter accelerator pump so one has to be careful to get the right kit.
R.
Re: can a '67 440 Chrysler "300" have an AVS? [Re: dogdays] #2525918
07/23/18 04:18 PM
07/23/18 04:18 PM
Dog after seeing him today I dont think it will change hands but I will keep the AP difference in mind cuz I did get jammed up over that once on a prior build (had to end up buying 2 kits).
Re: can a '67 440 Chrysler "300" have an AVS? [Re: GODSCOUNTRY340] #2526055
07/23/18 08:42 PM
07/23/18 08:42 PM
Fresno, CA
Jim_Lusk Offline
Jim_Lusk  Offline
Fresno, CA
Had my hands on one of those many years ago. A friend of mine had a '57 Chevy (283 two barrel). I found him the '66 intake and carb for $10. I rebuilt the carb for him. By the time he was done he had a four barrel on his car for about $30. He still couldn't beat my '66 Barracuda...
