Broken speedometer #2524303
07/19/18 11:40 PM
07/19/18 11:40 PM
USA
Z
z70dodge Offline OP
z70dodge  Offline OP
Z
USA
My speedometer makes a grinding howling sound when you get above 10mph and then the needle fluctuates. How should I go about fixing it. 1970 dodge challenger
Re: Broken speedometer [Re: z70dodge] #2524305
07/19/18 11:44 PM
07/19/18 11:44 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
The cable not be fully engaged in the speedometer head?
Try this........
Take it loose at the transmission.
Spin the inner cable slowly by hand while pushing it upwards.
Re-attach to the transmission pinion & check it.
Re: Broken speedometer [Re: Alaskan_TA] #2524308
07/19/18 11:48 PM
07/19/18 11:48 PM
USA
Z
z70dodge Offline OP
z70dodge  Offline OP
Z
USA
Ok I will try thanks! It always worked....but the car sat for a year or so without being touched. The first time I tried it out after sitting it acted up
Re: Broken speedometer [Re: z70dodge] #2524320
07/20/18 12:30 AM
07/20/18 12:30 AM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
If that doesn't work try removing the cable core from the speedo end of the cable housing and lubing it. I use a very thin coat of either white lube or Vaseline
Re: Broken speedometer [Re: stumpy] #2524335
07/20/18 01:32 AM
07/20/18 01:32 AM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
I'm beating on this one up
Re: Broken speedometer [Re: z70dodge] #2524798
07/20/18 11:39 PM
07/20/18 11:39 PM
USA
Z
z70dodge Offline OP
z70dodge  Offline OP
Z
USA
Ok thanks!
Re: Broken speedometer [Re: z70dodge] #2524829
07/21/18 12:54 AM
07/21/18 12:54 AM
RapidRobert Offline
RapidRobert  Offline
You might spin the cable with a reverseable drill (CCW) & see what develops.
Re: Broken speedometer [Re: z70dodge] #2529934
08/01/18 12:34 PM
08/01/18 12:34 PM
Sahuarita, Arizona
ChuxGTX Offline
ChuxGTX  Offline
Sahuarita, Arizona
I had this happen on a motorcycle and it was due to the cable not being lubricated. It ended up trashing my speedo.
