Transmission mount on mild street strip car #2524223
07/19/18 08:11 PM
07/19/18 08:11 PM
Creston, Iowa
3
340man4ever Offline OP
Creston, Iowa
What do you guys like to run for a transmission mount on a mild (375hp) street strip car? Car is 73 Dart with 360 /904 with Dynamic 9.5 converter/ 3.91 gears....will mostly be street driven, may take it to the strip a time or two and throw some 26 x 8 slicks on it.....Is a NAPA Premium style trans mount sufficient? I am planning on throwing a Schumacher torque strap on the engine on this car as well....Thoughts and suggestions appreciated....Thanks in advance drive
Curator at Adams County Speed Shop
Re: Transmission mount on mild street strip car [Re: 340man4ever] #2524374
07/20/18 03:36 AM
07/20/18 03:36 AM
Put a good non stretching type torque strap, motor tie down, on the left front of the motor first and then go have some fun twocents up
Re: Transmission mount on mild street strip car [Re: Cab_Burge] #2524426
07/20/18 10:35 AM
07/20/18 10:35 AM
s.w.fl
bonefish Offline
bonefish  Offline
s.w.fl
thats all i did on a 9 sec. b-body with an= old used stock mount.
Re: Transmission mount on mild street strip car [Re: bonefish] #2524530
07/20/18 01:56 PM
07/20/18 01:56 PM
Creston, Iowa
3
Creston, Iowa
Thank you for the input guys.....much appreciated! drive Torque strap is in my plans , yes
Re: Transmission mount on mild street strip car [Re: 340man4ever] #2525771
07/23/18 10:55 AM
07/23/18 10:55 AM
an8sec70cuda Offline
I like and use the poly trans mounts.
CHIP
'06 GMC 2500HD LBZ Duramax
