Engine Rebuild - Reuse of thrust plate, oil tab, slinger?
#2524129
07/19/18 03:26 PM
07/19/18 03:26 PM
Posts: 1,562 Macomb, MI
vinnyd76
Macomb, MI
When rebuilding your engines (e.g. small block) what is the recommendation for reuse of the thrust plate, oil slinger, oil tab, etc...? Reuse of original (or locate an original, if not present) or reproduction?
Re: Engine Rebuild - Reuse of thrust plate, oil tab, slinger?
[Re: vinnyd76]
#2524134
07/19/18 03:42 PM
07/19/18 03:42 PM
Posts: 14,889 up yours
Supercuda
Slinger and tab don't wear, clean and reuse no problem. Thrust plate might wear, inspect and if not worn clean and reuse.
[Re: vinnyd76]
#2524193
07/19/18 06:35 PM
07/19/18 06:35 PM
Posts: 1,255 Columbus, GA
Michael Ecks
Columbus, GA
Agree with supercuda. Those should all be no wear items. As long as the plate is flat across you should be good to go. Never seen a cam wear into one, my guess is there would have ro be serious other issues for it to do so.
"The happiness of your life depends upon the quality of your thoughts" ~ Roman Emperor Marcus Aurelius
