Re: An off balance thread..
[Re: 1DGEMAN]
#2634676
03/20/19 07:08 AM
03/20/19 07:08 AM
Posts: 4,664 Wichita
GY3
Wichita
An update to this: 440Source did offer to replace the balancer with a new one today. As I'm not excited about having the same issues and admittedly making more power than originally intended, I politely declined.
I do appreciate them getting back with me. So why did you raise such a fuss in public? The same reason they did about their vendor not getting back with them! I emailed them with pictures and never heard anything. It does irritate me that this happened and they need to be made aware that there is a problem with this product. This original thread was not "making a fuss in public" but rather serving as a warning to others that were considering this product.
[Re: GY3]
#2634684
03/20/19 08:00 AM
03/20/19 08:00 AM
Posts: 4,448 Phoenix, AZ
MoparBilly
Phoenix, AZ
I've always had a positive experience with everything I've purchased from 440 Source. But clearly, there are things they sell that I wouldn't even consider buying, regardless of the savings.
I picked up a used Innovators West balancer from a friend, because it was marked "BBC" at a swap meet, and then wouldn't fit on his 454. Gave him 100$, twenty years of flawless service. Have one of those TCI "Rattlers"...darn thing welded itself to the snout of my 440 crank, tried everything to remove it, no luck. I've got an SFI approved "PowerBond" on my stroker small block that has held up great the last 6 years.
"Livin' in a powder keg and givin' off sparks"
4 Street cars, 5 Race engines
[Re: BradH]
#2634704
03/20/19 08:47 AM
03/20/19 08:47 AM
an8sec70cuda
So many of these aftermarket dampers fail after such little use it's ridiculous. I've run stock old dampers on a few engines I raced and never had a problem. The only one I had fail was a BHJ damper...it replaced a stock damper b/c I was worried about it, lol. BHJ repaired it, but refused to discuss the issue. What about the BHJ failed? It slipped the outer ring over an inch after my first trip to the track w/ it. Called them, sent it back, got it back a week or so later "repaired". Tried calling them to talk to someone about it and they wouldn't talk to me. I sold it cheap.
[Re: an8sec70cuda]
#2634802
03/20/19 12:18 PM
03/20/19 12:18 PM
Posts: 4,673 On the parachute mount
n20mstr
IM TRYING TO SELL A BB FLUID DMAPER FOR ONLY $100.00...….LOL
ID NEVER USE A CHINESE DAMPER, THERE ARE OTHER PLACES TO SKIMP.
I DO USE 440 SOURCE OIL PAN AND VALVE COVERS, VERY HAPPY WITH BOTH...
....BAD A$$ STREET CAR.....
[Re: n20mstr]
#3036906
04/25/22 11:52 AM
04/25/22 11:52 AM
GY3
Wichita
To update this, I replaced the stock balancer with a Trickflow piece.
Very happy with it as it fit perfectly and aligned with all the pulleys.
