Magnum swap kick down linkage, what do I need #2522958
07/17/18 06:38 AM
07/17/18 06:38 AM
ME
79machocharger Offline OP
ME
360 magnum that I slappped in my satellite with an eddy 600 carb set up and 727 trans. Just wondering what I need to do the kick down linkage setup on it.
Re: Magnum swap kick down linkage, what do I need [Re: 79machocharger] #2523267
07/17/18 09:32 PM
07/17/18 09:32 PM
Lyons, CO
MileHighDart Offline
Lyons, CO
I went with the Lokar throttle cable, and kickdown cable on my Magnum swap. Just dont know if you're going to find any "stock" type parts that will work, both because of the magnums intake bolt being straight down instead of angled like an LA engine, and because the airgap makes the carb sit so high.
p.s. My car is an A-body, so you might need different cables for your B, not sure.
Re: Magnum swap kick down linkage, what do I need [Re: 79machocharger] #2523281
07/17/18 09:55 PM
07/17/18 09:55 PM
BDW Offline
BDW  Offline
Bouchillon has a really nice kit, used it for my EFI /518 set-up
https://www.bouchillonperformance.com/inc/sdetail/3578/589
Re: Magnum swap kick down linkage, what do I need [Re: BDW] #2523339
07/17/18 11:25 PM
07/17/18 11:25 PM
Kentucky
dfsmopars Offline
dfsmopars  Offline
Kentucky
iagree
‘72 Charger, 5.9 Magnum, Tremec 5 spd., Pro-Touring
‘14 Big Horn, Quad Cab, 4x4, 1500
