Re: sending unit
[Re: bonefish]
#2522534
07/16/18 01:22 PM
07/16/18 01:22 PM
Posts: 723 Michigan
BlueRacer69
Any updates on gas tank sending units that are atleast close to accurate? NO.......Most if not all are crap.
Re: sending unit
[Re: bonefish]
#2522546
07/16/18 01:45 PM
07/16/18 01:45 PM
Posts: 21,050 Niles , Ohio
therocks
Niles , Ohio
Bought one with 3/8 pickup a few years back for my 65.Is SS and was like 65 bucks off Ebay.Sender has worked decent since Ive instaled it.Just didnt save the place I bought it from.I installed a few from the same place but that was at least 7 years ago.Rocky
Chrysler Firepower
Re: sending unit
[Re: therocks]
#2522566
07/16/18 02:20 PM
07/16/18 02:20 PM
Posts: 7,274 s.w.fl
bonefish
s.w.fl
I got one from Dixie about 10 yrs ago that worked perfect but they cant get them any more.there was a thread on here a while back on how to calibrate the bad ones,but cant seem to find it.it was all about the OHMS
Re: sending unit
[Re: bonefish]
#2522640
07/16/18 04:20 PM
07/16/18 04:20 PM
Posts: 5,155 CT
GTX MATT
CT
I don't think the sender is the problem in many cases, its 50 year old wiring/connections/gauges. To verify you can test the sender. I've had 3 aftermarket sending units and they all test out per the FSM. All you need is an ohmmeter.
Re: sending unit
[Re: FJR doc]
#2522697
07/16/18 06:28 PM
07/16/18 06:28 PM
Posts: 20,600 in a cattle trailer down by th...
Guitar Jones
I wasted money on a repro sending unit that I couldn't calibrate with my fuel gauge on the bench. I found a NOS unit at Carlisle last year that was spot on. I suggest you try to find a NOS unit or send yours out for rebuilding. Send it out where?
Re: sending unit
[Re: bonefish]
#2522712
07/16/18 06:50 PM
07/16/18 06:50 PM
Posts: 1,307 BC, Canada
Black_Bee
BC, Canada
I put one of these on my '69 Super Bee w/ aftermarket sending unit. https://www.technoversions.com/MeterMatchHome.htmlWas a bit of a chore to set up (drain, measure, fill tank), but it is works great now! No more anxiety about how much fuel is in the tank because I know exactly how much there is.
Paul '69 Super Bee 383 EFI Turbo
Re: sending unit
[Re: OldFart]
#2522727
07/16/18 07:04 PM
07/16/18 07:04 PM
Posts: 723 Michigan
BlueRacer69
Stupid question for most folks... what does NOS stand for? I see it often when looking for parts for my 68 NOS stands for New Old Stock. Its means a brand new 30,40,50 year old part. Its old but still new meaning it was never used.
Re: sending unit
[Re: OldFart]
#2522728
07/16/18 07:04 PM
07/16/18 07:04 PM
Posts: 4,315 St. Louis, Mo
318 Stroker
St. Louis, Mo
Stupid question for most folks... what does NOS stand for? I see it often when looking for parts for my 68 NOS stands for "expensive"... Actually stands for New Old Stock. Parts that are unused, hence the term "new", but they were produced 30, 40, or maybe 50 years ago, hence the term "old".
Re: sending unit
[Re: Black_Bee]
#2522992
07/17/18 10:39 AM
07/17/18 10:39 AM
Posts: 1,057 Dallas, Texas
FC7cuda
Dallas, Texas
I put one of these on my '69 Super Bee w/ aftermarket sending unit. https://www.technoversions.com/MeterMatchHome.htmlWas a bit of a chore to set up (drain, measure, fill tank), but it is works great now! No more anxiety about how much fuel is in the tank because I know exactly how much there is. Killer item!! thanks for posting.
68 Charger 70 Cuda
Re: sending unit
[Re: bonefish]
#2523119
07/17/18 03:48 PM
07/17/18 03:48 PM
Posts: 357 The Garden State
LimelightCuda
The Garden State
Thanks for the information. My friend is trying to get his fuel gauge to work properly on his '66 Dart. I will pass it on to him.
Phil
1970 Barracuda Gran Coupe 1970 A66 Challenger Convertible
Re: sending unit
[Re: LimelightCuda]
#2524159
07/19/18 04:54 PM
07/19/18 04:54 PM
Posts: 2,336 Ball Ground, Georgia
Dixie
Thanks for the information. My friend is trying to get his fuel gauge to work properly on his '66 Dart. I will pass it on to him. There used to be a guy who advertised in Hemmings years ago that would rebuilt your sending unit and calibrate your gauge at the same time. Might be worth checking out the ads to see if he's still around. I think he was called the "clock doc", but not sure. Good luck !
