heater core in 66 Sport Fury? #2522304
07/15/18 10:07 PM
07/15/18 10:07 PM
Penna
70satelliteguy Offline OP
Penna
How much of a job to get to the heater core? Got one leaking!!!
Can you repair or re core one or is it just better to get a new one?
Thanks Mike
Re: heater core in 66 Sport Fury? [Re: 70satelliteguy] #2522322
07/15/18 10:42 PM
07/15/18 10:42 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Haven't done that job on that car, so I'm no help there. But it's essentially a mini-radiator, and can be pressure tested, cleaned, re-soldered and/or recored. Your local radiator shop might also have a replacement source. Dimensions are usually pretty critical as it sits inside the heater case.
Re: heater core in 66 Sport Fury? [Re: 70satelliteguy] #2522344
07/15/18 11:10 PM
07/15/18 11:10 PM
Spring Hill Fl
65Fury440 Offline
65Fury440  Offline
Spring Hill Fl
I took the whole box out of my 65 with no air. Probably took a half hour to get out.
The studs go through the firewall, control cables, wire plug and ducting removal go pretty fast.
If the cores are the same (I think they are), Id sell you mine.
Re: heater core in 66 Sport Fury? [Re: 70satelliteguy] #2522387
07/16/18 01:24 AM
07/16/18 01:24 AM
colorado
savoy64 Offline
savoy64  Offline
colorado
in the same vintage trucks the heater core actually has short pieces of rubber hose inside the box-----the rubber may be leaking......buy new hose...
Re: heater core in 66 Sport Fury? [Re: 70satelliteguy] #2522390
07/16/18 01:33 AM
07/16/18 01:33 AM
Supercuda Offline
Supercuda  Offline
Service manual
http://www.mymopar.com/index.php?pid=109
page 1-10
If it's anything like the Dart I replaced a core on a blood sacrifice will occur.
Don't be the exception.
Re: heater core in 66 Sport Fury? [Re: 70satelliteguy] #2522391
07/16/18 01:36 AM
07/16/18 01:36 AM
KY
65pacecar Offline
65pacecar  Offline
KY
Its an easy job, 1 hour at most. Pull the box, replace the core, clean up the box in the process a d replace 65_66 are the basically the same. Check Napa and Carquest, I th I nk they still carry the core. If you buy a new one do a pressure check before installing. Old radiatpr shops can fix them too.
Re: heater core in 66 Sport Fury? [Re: 70satelliteguy] #2522405
07/16/18 03:35 AM
07/16/18 03:35 AM
Morristown Tn.
71birdJ68 Offline
71birdJ68  Offline
Morristown Tn.
After you get the old on out, send it to Glen Ray radiators and they will repair, or re core it. Don't waste money on a china core when the one you have actually fits.
