Crown Vic front end
#2522121
07/15/18 01:40 PM
07/15/18 01:40 PM
Posts: 18,575 Dreaming of the 808
AZ_A12_BEE
Dreaming of the 808
Anybody ever use a Crown Vic front end, they look like a nice unit that can be installed fairly fast.
69.5 A12 Bee, first purchased in 1976, car 169 on registry
69 Coronet R/T 440/4 spd
69 Coronet 500 Conv H code 383 4bbl/auto
37 Plymouth PU
Find your spot on earth and ride it.
Re: Crown Vic front end
[Re: AZ_A12_BEE]
#2522127
07/15/18 02:00 PM
07/15/18 02:00 PM
Posts: 14,889 up yours
Supercuda
Other than width it's a neat package.
[Re: AZ_A12_BEE]
#2522824
07/16/18 10:15 PM
07/16/18 10:15 PM
Supercuda
Might fit, what's the track?
Near as I can find, not being a truck guy, the 63's track is 64.7"
the Crown Vic is 62.8"
So it ought to work but the kicker is it appears that the frame width is the same at 34" for both.
Some time with a tape measure and online looking at CV swaps might pay dividends.
[Re: AZ_A12_BEE]
#2522897
07/16/18 11:50 PM
07/16/18 11:50 PM
Supercuda
Panther rim offset answers https://www.crownvic.net/ubbthreads/ubbthreads.php?ubb=showflat&Number=1061930Pretty sure it's not an issue if it doesn't hit. the stock rims have the offset they have to fit the chassis, the truck will have a different setup and will need rims to fit that.
[Re: poorboy]
#2523839
07/18/18 11:28 PM
07/18/18 11:28 PM
AZ_A12_BEE
Dreaming of the 808
You will have to remove the sweptline's under the motor crossmember, the CV's crossmember will occupy the same area. Then you will have to add a flat surface to the bottom of the Sweptline's frame from the rad support to the end of the rear spring hanger to get rid of the Mopar hump in the font frame rails so the CV suspension has something to "bolt" to. That flat surface will have to be long enough to pick up the back end of the lower control arm mounting as well, hopefully they are close enough inline with the other mounting holes.
The CV has something like 4" of backspacing on the wheels, you did get the wheels as well, right?
Take pictures of your progress. It would be nice to have a documented step by step procedure of another option for a front clip, as limited as it might be. Gene I was thinking of using this in my 37 Plymouth
37 Plymouth PU
[Re: flyman]
#2524009
07/19/18 11:44 AM
07/19/18 11:44 AM
Posts: 2,683 Des Moines IA
Soopernaut
Des Moines IA
I was thinking on putting one under a 63 sweptline?? It's been done by quite a few people. There is still a lot of frame hacking required to do it.
1970 Dodge d100/eventually going on a 77 D100 frame
