Building dakota for son #2521894
07/14/18 05:44 PM
07/14/18 05:44 PM
maryland
mhead Offline OP
mhead  Offline OP
maryland
Hey guys what are you all using for small block headers?I'm currently putting together a 360 and 904 that should run low 12's to high 11's.I assume a standard truck pan will work?Any feedback appreciated thanks
Re: Building dakota for son [Re: mhead] #2521912
07/14/18 07:37 PM
07/14/18 07:37 PM
Memphis,TN
J. Hammer Offline
J. Hammer  Offline
Memphis,TN
Dakota pan and pickup tube. Hooker comp headers.
Re: Building dakota for son [Re: mhead] #2521991
07/15/18 12:45 AM
07/15/18 12:45 AM
Missouri U.S.A.
71yelladustr Offline
Missouri U.S.A.
Hooker 5803 is what you need. Standard truck oil pan won’t fit. Needs to be Dakota/Durango style oil pan.
392 gen III hemi on E-85 727 trans Dana 60
10.02@134
Re: Building dakota for son [Re: mhead] #2522015
07/15/18 01:54 AM
07/15/18 01:54 AM
michigan
6pakdakota Offline
6pakdakota  Offline
michigan
Stock manifolds flipped with an s480 turbo. 😎.
Re: Building dakota for son [Re: mhead] #2522083
07/15/18 11:55 AM
07/15/18 11:55 AM
New Mexico
Adobedude Offline
Adobedude  Offline
New Mexico
What year Dakota?
2001 Dodge Dakota
408 All Motor
11.27 @ 117.83 mph
2017 NM Mopar Challenge Series Champion.
Re: Building dakota for son [Re: Adobedude] #2522174
07/15/18 03:42 PM
07/15/18 03:42 PM
maryland
mhead Offline OP
mhead  Offline OP
maryland
It's a 91 that has a 4 cylinder,5 speed short bed.Son is 16 and wants to bracket race in summit high school class and street class.I'm using a 71 360 block,.060 over,scat I beam rods,icon forged flat tops,ported 2.02 j heads that went 10.8's on my demon,rpm air gap intake,hp 750 holley,904 with 10" ati.I was hoping someone made a bigger header than 1 5/8".My experience with hooker headers is the flanges don't match the heads very well.When I searched for a oil pan all I found was 318 pans.Anyone know what these trucks weight?Thanks
Re: Building dakota for son [Re: mhead] #2522184
07/15/18 04:11 PM
07/15/18 04:11 PM
Missouri U.S.A.
Missouri U.S.A.
Use a factory magnum oil pan. They weigh anywhere between 3100 to 3300 lbs depending on how they are equipped.
10.02@134
Re: Building dakota for son [Re: mhead] #2522420
07/16/18 08:02 AM
07/16/18 08:02 AM
Memphis,TN
J. Hammer Offline
J. Hammer  Offline
Memphis,TN
For the low hp combo your asking about the 1 5/8 headers are not a problem. Let us know if you find a great header for an early Dakota.
Re: Building dakota for son [Re: mhead] #2523360
07/18/18 12:07 AM
07/18/18 12:07 AM
Central Missouri Fort Leonard...
mopar65 Offline
mopar65  Offline
Hey you got any pics of your Dakota? I am building a 91 SB my self.
3520 pound race ready 1973 Street/Strip Dodge Dart - Stock stroke 440/727 10.49 @ 125.0 on 93 pump gas & ET Street Radials. More to come... ( SGT Miller) Proudly served 12 years in the US ARMY RESERVES support our troops
Re: Building dakota for son [Re: mopar65] #2523368
07/18/18 12:21 AM
07/18/18 12:21 AM
Memphis,TN
J. Hammer Offline
J. Hammer  Offline
Memphis,TN
One that I used to own and a current Driver.
Re: Building dakota for son [Re: J. Hammer] #2523418
07/18/18 02:25 AM
07/18/18 02:25 AM
mopar65 Offline
mopar65  Offline
Hey thanks for the pics. Nice looking Dakotas there. My 91 is also a sport but in blue. But my 91 the cab was rusted out at the front cab mounts etc. I ended up buying a rust free 87 long bed. It’s a V6 auto truck. So decided to pull the cab off the 87 and put it on my 91 SB frame. What kind of E/T are you wanting to run? Mine should be in the low 11 in the 1/4 if I ever get it done. Lol also thanks for the pics
Re: Building dakota for son [Re: mopar65] #2523422
07/18/18 03:15 AM
07/18/18 03:15 AM
Memphis,TN
J. Hammer Offline
J. Hammer  Offline
Memphis,TN
The first truck has run low 6's 1/8 mile,pump gas hyd cam ,3.73 gear,3500lb(w driver) drive up to 80 miles to the track street truck. Can't comment on the later version,still testing stuff.
Re: Building dakota for son [Re: J. Hammer] #2523460
07/18/18 09:26 AM
07/18/18 09:26 AM
mopar65 Offline
mopar65  Offline
Wow that sounds like a great runing truck. Care to tell more anout the build. I want to drive mine on the street a lot. I have a 518 auto I can build. But then I want to build a 904 for a faster ET. Lol
