Re: door lock fix or replacement?
[Re: 64Bel]
#2522182
07/15/18 04:06 PM
07/15/18 04:06 PM
Posts: 15,713 Central Florida
larrymopar360
Stud Muffin
Stud Muffin
Central Florida
Did you try ebay for NOS set?
I got NOS set of two doors and ignition for my '79 for $50
Facts are stubborn things.
[Re: larrymopar360]
#2522190
07/15/18 04:17 PM
07/15/18 04:17 PM
Posts: 91 Calgary, AB
64Bel
Calgary, AB
I got NOS set of two doors and ignition for my '79 for $50 The older ones like I need have a larger face and a smaller body/hole in the door and a lot harder to find. Napa had the locks listed for $52 CAD, but were the later style. edit: the earlier ones are closer to $300 CAD on ebay
[Re: 64Bel]
#2523354
07/17/18 11:49 PM
07/17/18 11:49 PM
Posts: 10,178 Someplace you aren't
SomeCarGuy
Can you take the tumblers out and make it a dummy lock? Old stuff isn’t real hard to jimmy so no biggie on security anyway. Can make them all work on the same key, any key, pocket knife, or screw driver!
I want my fair share
[Re: SomeCarGuy]
#2523429
07/18/18 03:42 AM
07/18/18 03:42 AM
64Bel
Calgary, AB
Probably not too hard to change the pins to match the ignition key..the pin cover looks to be a PITA compared to the later ones.
Main problem is that the actuator arm has fallen off because the end is no longer mushroomed and there isn't enough meat on there to use an E clip or something.
