Reproduction original style spring hose clamps
#2512098
06/23/18 11:31 AM
06/23/18 11:31 AM
Posts: 76 Pittsburgh, PA
roadrunnerh
Pittsburgh, PA
So I am installing these on my 68 RR. I've noticed in two complete sets I have there are two different size large clamps for upper and lower rad hose. Which is for which? I used the smaller two on my upper hose because the larger one was able to turn completely once unsprung on the rad end of upper hose. Help.
Harry 1968 Road Runner 1975 Scamp
Re: Reproduction original style spring hose clamps
[Re: roadrunnerh]
#2512122
06/23/18 12:15 PM
06/23/18 12:15 PM
roadrunnerh
Pittsburgh, PA
Answer to my own question.... LOL
stamped "RC34" Lower Hose
stamped "RC30" Upper Hose
[Re: roadrunnerh]
#2512148
06/23/18 01:12 PM
06/23/18 01:12 PM
Posts: 21,397 It's a dry heat
gtx6970
It's a dry heat
stamped "RC30" Upper Hose yep
[Re: moparx]
#2512180
06/23/18 02:27 PM
06/23/18 02:27 PM
Posts: 16,133 Mesa, Arizona
dart4forte
Mesa, Arizona
from what i hear, and have observed on my buddy's 72 duster, the reproduction clamps, coupled with the thinner wall section hoses, don't clamp tight enough. i "think" the solution is to peruse the grainger catalog for the correct size "range" of these clamps for your application. thoughts on this ? I agree. I've had several hoses pop off due to those clamps. Mainly lower radiator. I temporarily place a regular clamp on the lower rad hose until the next time I change the coolant. On the heater hoses going into the firewall they've weeped a bit. I moved the clamp around and it's stopped. Other than those hoses the clamps seem to be holding. As a side note, make sure you use the proper clamp pliers. With using regular pliers the clamps sometime wont hold and will go flying. They can take out a windshield or chip paint.
Abe Lincoln
[Re: roadrunnerh]
#2512212
06/23/18 03:26 PM
06/23/18 03:26 PM
roadrunnerh
Pittsburgh, PA
On mine, we shall see. They seem really tight, but the proof will come in a couple days when I fire it up.
[Re: roadrunnerh]
#2512588
06/24/18 01:54 PM
06/24/18 01:54 PM
Posts: 3,464 Back in NJ....
EWJ
Back in NJ....
I've had issue with the heater hose ones not clamping enough on the heater core tubes.
Ed EastCoast Land Yacht Assoc. 1967 Newport Conv: 440/4 speed 1969 GTX: 440/4 speed, TX9/TX9, A34, N96 1970 Super Bee: 383/4 speed, B5/B7 1970 Coronet RT: 440/4 speed, A34, N96 1970 Coronet RT: 440/auto, A36, N96 1970 Road Runner convertible: 383/4 speed TX9/D6XW 1970 GTX: 440+6/727, A32, N96 2001 Dodge 2500 HO CTD, 6 speed, 4x4 quad cab long bed "The early bird may get the worm, but the 2nd mouse gets the cheese".
[Re: moparx]
#2512828
06/25/18 12:19 AM
06/25/18 12:19 AM
Posts: 18,157 Mass
DAYCLONA
Mass
from what i hear, and have observed on my buddy's 72 duster, the reproduction clamps, coupled with the thinner wall section hoses, don't clamp tight enough. i "think" the solution is to peruse the grainger catalog for the correct size "range" of these clamps for your application. thoughts on this ? McMaster Carr has a better selection and quality, and the plating is identical to OEM This is the only route to go if using "newer" hoses as you stated the hose OD is slightly smaller than OEM....and the current offering of Corbin clamps are for once spot on repros, unfortunately the hose mfg's have decreased the wall thickness of repro and aftermarket hoses, generally the upper/lower rad hoses are the ones affected.... FYI...and trying to "shrink" the OD of a Corbin clamp to increase the tension only results in "egging" the clamp, and it will still leak/fail...so purchase the right size clamp for proper fit...
[Re: DAYCLONA]
#2512964
06/25/18 12:12 PM
06/25/18 12:12 PM
Posts: 19,336 north of coder
moparx
from what i hear, and have observed on my buddy's 72 duster, the reproduction clamps, coupled with the thinner wall section hoses, don't clamp tight enough. i "think" the solution is to peruse the grainger catalog for the correct size "range" of these clamps for your application. thoughts on this ? McMaster Carr has a better selection and quality, and the plating is identical to OEM This is the only route to go if using "newer" hoses as you stated the hose OD is slightly smaller than OEM....and the current offering of Corbin clamps are for once spot on repros, unfortunately the hose mfg's have decreased the wall thickness of repro and aftermarket hoses, generally the upper/lower rad hoses are the ones affected.... FYI...and trying to "shrink" the OD of a Corbin clamp to increase the tension only results in "egging" the clamp, and it will still leak/fail...so purchase the right size clamp for proper fit... mcmaster carr was what i was thinking about, not grainger. thanks for setting it straight ! and you are spot on about trying to "shrink" those clamps. my buddy tried that after i told him what would happen, and he was "rewarded" with a fuel leak at the filter. a fuel injection style clamp later solved that issue. the odd thing about my buddy is, his cars are slightly modified, yet he wants to stick with factory "known issues" using some of the repro parts available today. just an example, under the hood his cars look like a very nice stock style, detailed setup. then you notice the ribbed plastic, GM wiring loom crap...... oh well, it's his car after all. if he is happy, that's all that counts.
