Which Scirocco Style Radiator??
#2511920
06/22/18 10:02 PM
06/22/18 10:02 PM
Posts: 2,533 Alexandria, LA
Blucuda413
Alexandria, LA
I currently have a Ron Davis Scirocco radiator setup which has served me well with my NA engines. This older radiator seems to be rather small with a core that is only maybe 1 1/4" thick. I'm going to a forced induction setup and thought a little better radiator would be helpful. Which of the common Scirocco radiators would be best: Griffin, AFCO, Ron Davis, Champion, or some other I can't think of at the moment. It needs to be a Scirocco style because I have the shroud, fan, mount, and overflow can etc. Which would help me the most?? Thanks, Max
Re: Which Scirocco Style Radiator??
[Re: Forest]
#2518394
07/06/18 01:31 PM
07/06/18 01:31 PM
Posts: 20,144 PA.
pittsburghracer
I would shy away from the Scirocco style radiators. After 2-3 years of hard use they start spreading the plastic tanks apart.
[Re: Blucuda413]
#2518677
07/07/18 02:25 AM
07/07/18 02:25 AM
Posts: 20,144 PA.
pittsburghracer
It saids AFCO in his post.
