Re: my fresh BB won't idle
[Re: JAMESDART]
#2513852
06/27/18 12:14 PM
06/27/18 12:14 PM
I rarely use the paper gaskets with the valley pan.
[Re: fast68plymouth]
#2513867
06/27/18 12:53 PM
06/27/18 12:53 PM
Posts: 3,277 West Coast, USA
jbc426
West Coast, USA
I rarely use the paper gaskets with the valley pan. Curious what sealant if any you use, Dwayne.
[Re: JAMESDART]
#2514382
06/28/18 12:37 PM
06/28/18 12:37 PM
Years ago I used “high tack”.
More recently I’ve used a very thin smear of black “the right stuff”.
I’ve run them dry as well....... usually when I know there will be manifold swaps involved.
[Re: JAMESDART]
#2514903
06/29/18 01:11 PM
06/29/18 01:11 PM
Until I had things more sorted out, I’d remove the pcv valve and use 2 breathers, and lock out the distributor...... start out at like 32deg.
