Re: Dakota clip- who has done and retained the EFI?
[Re: flyman]
#2517771
07/05/18 12:34 AM
07/05/18 12:34 AM
Posts: 16,452 Canada
CrAzYMoPaRGuY
Canada
Keep these PINs per a 94 dakota service manual
PINS 1 map sensor 2 ECT sensor 3 Battery feed 4 sensor return 6 5v supply 7 8v supply 9 Ignition feed 10 not needed with 727 11 Ground 12 Ground 13 Inj Driver4 14 Inj Driver3 15 Inj Driver2 16 Inj Driver1 17 Inj Driver7 18 Inj Driver8 19 Ign Coil Driver 20 Gen Feild Driver 21 Air Temp Sensor 22 TP Sensor 24 Reference Pickup 25 Data link 27 AC compressor (if keeping AC) 29 Brake sense (if keeping cruise) 30 P/N switch 32 MIL 33 VSS (if keeping dakota cruise) we got rid of) 34 AC WOT relay (if keeping ac- we got rid of) 35 EGR Solenoid (we deleted EGR) 37 Trans OD light (we got rid of) 38 Inj Driver5 39 IAC 40 IAC 41 Heated O2 Sensor 43 Tach (we kept) 44 CMP sensor 45 Data llink 47 VSS pick up (we kept for now) KEEP 47-50, 53 keep if using dakota cruise 48 VSS set/coast (we got rid of) 49 VSS on/off (we got rid of) 50 VSS resume/accel 51 ASD relay and fuel pump relay driver 52 Evap purge (we got rid of) 53 VSS vent (we got rid of) 54 EMCC solenoid (we got rid of) 55 Trans OD solenoid (we got rid of) (keep if using 42rh or 46rh) 57 ASD bat supply 58 Inj Driver6 59 IAC 60 IAC This is what I used to make mine work.
And pin#3 direct battery fused at 30 amps spliced to feed pins 30 of ASD and Pin 30 of fuel pump relay Pin 9 IGN switched voltage spliced to feed 12v side of ASD and fuel pump relay. Pin 11 and 12 grounds. Pin 29 to brake switch Pin 30 to park neutral switch Pin 51 Switched ground wire to Pin 86 on ASD and fuel pump relay Pin 57 pin on 87 on ASD relay I also had a 1994 Dakota Service manual and a good understanding of electronics. Hope this helps I think you may still find this in the tech archives also
Awesome. THANKS!!!
CrAzYMoPaRGuY
[Re: CrAzYMoPaRGuY]
#2520999
07/12/18 01:13 PM
07/12/18 01:13 PM
Posts: 20,600 in a cattle trailer down by th...
Guitar Jones
IIRC the 80's injected Chargers and maybe others used a speed sensor that connected to the trans and then the speedo cable connected to the sensor so you could have both. I don't know if they used the same counter though. But I think there are only 4 poles in the sensor. If you keep the speed sensor and brake light switch signals you won't have to use switches for the O/D and lockup.
I'm going to swap a complete 93 Ram Charger dash, engine, HVAC, fuel tank and wiring harnesses into my 74 crew cab. I plan to use everything from the RC including the steering column so mine should be easy. What I would like to do though is an OBD II swap for the engine management so I can modify the engine with an intake, cam and heads. The hot wire harness looks like an easy way to go but at $1000 it's pretty steep. Especially when you consider you still have to get a PCM and tune it as well. So it may remain stock for awhile.
[Re: CrAzYMoPaRGuY]
#2521228
07/12/18 10:10 PM
07/12/18 10:10 PM
Posts: 14,889 up yours
Supercuda
STANDARD MOTOR PRODUCTS SC108 is the sensor for older transmissions that lets you keep the cable and still have an electronic signal for the computer. But you'd need the pinion adapters to put into the 95 setup.
[Re: Supercuda]
#2522440
07/16/18 09:56 AM
07/16/18 09:56 AM
Guitar Jones
You know I can't remember how the 95 Dakota tail housing with the sensor looks. Does the 95 still have a governor?
[Re: Guitar Jones]
#2522796
07/16/18 09:13 PM
07/16/18 09:13 PM
Supercuda
You know I can't remember how the 95 Dakota tail housing with the sensor looks. Does the 95 still have a governor? Looks like a maybe, might have to slide under the truck and just look.
[Re: Supercuda]
#2523141
07/17/18 04:21 PM
07/17/18 04:21 PM
CrAzYMoPaRGuY
Canada
STANDARD MOTOR PRODUCTS SC108 is the sensor for older transmissions that lets you keep the cable and still have an electronic signal for the computer. But you'd need the pinion adapters to put into the 95 setup. Why does the ECU need an electronic speedo signal?? I know the 95 dakota speedo needs the transducer because it has an electronic speedo, but what does the ECU need the signal for? Sorry but I'm old school, I have limited EFI experience!!
CrAzYMoPaRGuY
[Re: CrAzYMoPaRGuY]
#2523238
07/17/18 07:40 PM
07/17/18 07:40 PM
Guitar Jones
It needs to know the vehicle speed not just for O/D and cruise but also know the vehicle is not just sitting still. Early efi cars would stall on decell without a vss signal.
[Re: CrAzYMoPaRGuY]
#2523246
07/17/18 08:17 PM
07/17/18 08:17 PM
CrAzYMoPaRGuY
Canada
Is there a way to run speedo signal while at the same time running a mechanical speedo cable?
CrAzYMoPaRGuY
[Re: CrAzYMoPaRGuY]
#2523275
07/17/18 09:47 PM
07/17/18 09:47 PM
Supercuda
Is there a way to run speedo signal while at the same time running a mechanical speedo cable? STANDARD MOTOR PRODUCTS SC108 is the sensor for older transmissions that lets you keep the cable and still have an electronic signal for the computer.
[Re: Supercuda]
#2523277
07/17/18 09:50 PM
07/17/18 09:50 PM
CrAzYMoPaRGuY
Canada
Is there a way to run speedo signal while at the same time running a mechanical speedo cable? STANDARD MOTOR PRODUCTS SC108 is the sensor for older transmissions that lets you keep the cable and still have an electronic signal for the computer. Awesome!!!! THANKS!!!
CrAzYMoPaRGuY
[Re: dodgew350]
#2632909
03/15/19 09:20 AM
03/15/19 09:20 AM
Posts: 425 Eastern Ontario
shaker340
Eastern Ontario
Regarding the oil pressure question, I used a 96 Dakota harness merged with a 99 Ram engine harness and the 99 JTEC computer for 5.2L. The motor fired up without the oil pressure sender hooked up. I think its only there just to send on to the gages.
I am very interested in the Speedo question, we are using the 46RE and trying to use an aftermarket speedo.
Mike
2008 Challenger SRT8 1940 Chrysler Royal coupe
[Re: shaker340]
#2634322
03/19/19 09:24 AM
03/19/19 09:24 AM
Guitar Jones
Mike I'm thinking your best alternative is a GPS speedometer.
[Re: Guitar Jones]
#2634364
03/19/19 11:27 AM
03/19/19 11:27 AM
shaker340
Eastern Ontario
The Speedo is able to read digital info as it came with a convertor for a 727. Once we get it hooked up will see what it does.
Mike
