Re: 87 octane 636hp 499 stroker [Re: CoronetCrazed] #2512410
06/24/18 12:29 AM
06/24/18 12:29 AM
Wichita
GY3 Offline
GY3  Offline
Wichita
Originally Posted By CoronetCrazed
GY3, could you tell me more about your build? What kind of suspension are you running? What tires? How do you like the hydraulic roller? Did you bush your lifter bores? I was leaning towards a solid flat for ease of use and cost but I'm still open to other alternatives. It seems every cam has its positives and negatives and people get pretty passionate about it!
AndyF, I need to go back and read you stroker cam shootout and your book again. I remembered you saying you don't need much cam for a street build. I've probably getting a little wrapped up in reading other people's posts who do more true street/strip!
Sure!
Cam is Howards 288/294 (235/241 @ .050"), .545/.545 hydraulic roller. I did not bush the lifter bores. CNC Stealths, Crane ductile iron rockers, Manton pushrods, Molnar 4.25 crank and 7.1" rods, Mahle pistons, 2800 stall Turbo Action converter, fwd pattern Cheetah mvb, Dana 60 with spool and 3.54 gears.
3 way CE shocks up front with 6 cylinder bars. Cal-Trac setup with their 9 way shocks out back. ET Street Pro rear tires. Weighs 3600 lbs. with my 210 lbs. behind the wheel.
I went with a hydraulic roller after having a flat tappet MP.557 go flat. I absolutely love it! Very quiet valvetrain.
'63 Dodge 330
11.19 @ 121 mph
Pump gas, n/a, through the mufflers on street tires with 3.54's. 3,600 lbs.
10.01 @ 133mph with a 250 shot of nitrous an a splash of race gas. 1.36 60 ft. 3,700 lbs.
Re: 87 octane 636hp 499 stroker [Re: CoronetCrazed] #2512440
06/24/18 02:03 AM
06/24/18 02:03 AM
AndyF Offline
AndyF  Offline
The low deck 470 that I had 20 years ago was 10:1 compression with HP manifolds and Edelbrock heads. It just had a Mopar 0.528 flat tappet cam in it. That engine would roast the tires in the first 3 gears and would run high 11's in a 3800 lb B body. If you are really just driving on the street then you don't need much more than that. If you are racing then sure, turn up the wick but then you have to live with the downside.
Re: 87 octane 636hp 499 stroker [Re: AndyF] #2512444
06/24/18 02:16 AM
06/24/18 02:16 AM
Wichita
GY3 Offline
GY3  Offline
Wichita
I ran that .528 MP cam in a 440 with 3.23 gears and loved it!
'63 Dodge 330
11.19 @ 121 mph
Re: 87 octane 636hp 499 stroker [Re: CoronetCrazed] #2512466
06/24/18 08:03 AM
06/24/18 08:03 AM
upstate western ny
sogtx Offline
sogtx  Offline
upstate western ny
Originally Posted By sogtx
Ill have a dyno pull in a week or so with a stroked 440
10:1 and 240 trick flows , hydraulic rollers and cast manifolds and six pak
Cant wait to see - hope for 500 .. builder thinks 7.
594 lift , seems high , but I guess the roller deal tames it. Not sure
how it all works — i hope it idles like my ol bob k cam
Everyone involved says it will be tame and super reliable
Nice! Look forward to seeing you post the results! You'll have to let us know the street manners once you drop it in! What kind of lifters did you go with?
We used
Morell Hydraulic Rollers
