No Shift/IAC
#2511518
06/21/18 10:35 PM
06/21/18 10:35 PM
Posts: 1,534 Florida
CHRGR69
89 Dakota 3.9 auto. Suddenly the trans won's shift into 3rd. Fluid level is full and clean. No burnt smell. Then when stopping at a light/stop sign it will stumble, but not stall. I remember reading something about the IAC being tied into the trans shifing??
Grandma always said I had "hands of gold"!
Re: No Shift/IAC
[Re: A727Tflite]
#2511563
06/22/18 12:23 AM
06/22/18 12:23 AM
CHRGR69
3 speed with the OD on off button? Reverse is fine.
Re: No Shift/IAC
[Re: CHRGR69]
#2511781
06/22/18 03:34 PM
06/22/18 03:34 PM
Posts: 20,622 in a cattle trailer down by th...
Guitar Jones
1st, 2nd, and 3rd are hydraulically controlled. O/D is controlled by a solenoid.
Re: No Shift/IAC
[Re: CHRGR69]
#2512166
06/23/18 02:01 PM
06/23/18 02:01 PM
Posts: 25,720 Rio Linda, CA
John_Kunkel
When it won't shift to 3rd, try accelerating a little more and then throttling back to idle; will it shift then?
Re: No Shift/IAC
[Re: John_Kunkel]
#2512654
06/24/18 04:38 PM
06/24/18 04:38 PM
CHRGR69
I tried it, but hard to tell if it shifted. I'm leaning toward saying yes, because it didn't stumble when I came to a full stop.
Re: No Shift/IAC
[Re: J_BODY]
#2513135
06/25/18 06:16 PM
06/25/18 06:16 PM
John_Kunkel
Front clutch seal/rings or governor sealing rings.
A strong Reverse isn't always a good gauge of front clutch operation; the line pressure triples in Reverse so a weak clutch will often work acceptably in Reverse.
Re: No Shift/IAC
[Re: John_Kunkel]
#2513871
06/27/18 12:58 PM
06/27/18 12:58 PM
CHRGR69
I finally got around to pulling codes and I got a "DTC:15 NO VEHICLE SPEED SENSOR SIGNAL DETECTED DURING ROAD LOAD CONDITIONS". A symptom of this sensor failing are "can cause an automatic transmission to go into limp mode, and not shift above second gear". Think I found my problem.
Re: No Shift/IAC
[Re: CHRGR69]
#2514115
06/27/18 08:43 PM
06/27/18 08:43 PM
Guitar Jones
No you didn't if you are accurately describing the condition. Since you don't have an electronically controlled transmission there isn't a "limp mode". No speed sensor signal will result in no 4th gear shift but it has nothing to do with the 1/2 or 2/3 shift. Please try to accurately describe the condition you are trying to fix if you want accurate information to fix it.
Re: No Shift/IAC
[Re: Guitar Jones]
#2514353
06/28/18 11:39 AM
06/28/18 11:39 AM
CHRGR69
From a dead stop, when I accelerate, is that 1st gear? If so, I than feel 2 more shits after that, and than it hangs up (4th gear?). Maybe I did describe it wrong. I thought these were 3 speed transmissions.
Re: No Shift/IAC
[Re: CHRGR69]
#2514575
06/28/18 07:23 PM
06/28/18 07:23 PM
Guitar Jones
I replied to your PM. Don't want to type all over again, I'm on my tablet.
Re: No Shift/IAC
[Re: CHRGR69]
#2518439
07/06/18 03:09 PM
07/06/18 03:09 PM
CHRGR69
UPDATE! Sensor installed, trans shifting normally again!
