Re: BB solid roller lifter
[Re: Dartski68]
#2512994
06/25/18 01:09 PM
06/25/18 01:09 PM
an8sec70cuda
Just FYI...Just got an email back from Isky saying my old style needle bearing Red Zone lifters can be converted to solid bushings for less than half the price of a set of new ones.
[Re: Dartski68]
#2513002
06/25/18 01:18 PM
06/25/18 01:18 PM
Posts: 14,479 So. Burlington, Vt.
Chip, if you go that route...... get the upgraded “speedway” bushings.
[Re: fast68plymouth]
#2513048
06/25/18 02:47 PM
06/25/18 02:47 PM
an8sec70cuda
Chip, if you go that route...... get the upgraded “speedway” bushings. OK, I was quoted $650 for the EZX upgrade up to 900 psi spring pressure and $720 for the EZMAX upgrade for over 900 psi and/or supercharged/turbo applications.
[Re: Dartski68]
#2513052
06/25/18 02:55 PM
06/25/18 02:55 PM
I think the speedway bushings hold up better when you only have splash oiling.
[Re: Dartski68]
#2514406
06/28/18 01:08 PM
06/28/18 01:08 PM
hemi-itis
Last season I rebuilt a set of Comp 869s for the 3rd time.1 lifter had to be replaced with the superceded lifter.Even though the the link bar is at a different height it was not an issue.I have gone upwards of 8k miles on a rebuild which was close to 10k miles.640ish lift with 560 over the nose. 545 inch blown hemi that makes the track 4 or 5 times a year if I'm lucky.
