Re: Sure Grip ID please
[Re: shakerjoe]
#2510563
06/19/18 10:55 PM
06/19/18 10:55 PM
Posts: 14,889 up yours
Supercuda
Count the teeth and do the math
[Re: shakerjoe]
#2510568
06/19/18 11:06 PM
06/19/18 11:06 PM
Posts: 1,058 Dallas, Texas
FC7cuda
Dallas, Texas
The ring gear teeth # and the pinion gear teeth # are on the ring gear, requires math. 44/9=4.88 gears
68 Charger 70 Cuda
[Re: shakerjoe]
#2510570
06/19/18 11:08 PM
06/19/18 11:08 PM
Posts: 5,777 ohio
ruderunner
ohio
44/9 = 4.88 ratio
Looks like a clutch type sure trip. 742 casting is large bearing straight shaft pinion.
The clutches can be replaced if worn.
Overall not a bad score if you need the stump puller gears.
Angry white pureblood male
