Mopar Performance R3 block #2510479
06/19/18 07:04 PM
06/19/18 07:04 PM
begood Offline OP
begood  Offline OP
Does anyone know where I can find all the specs on an R3 block I just bought? It is part number P4332908.
THERE IS NO SUCH THING, AS TOO MUCH HORSEPOWER
Re: Mopar Performance R3 block [Re: begood] #2510481
06/19/18 07:12 PM
06/19/18 07:12 PM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
That doesn't really sound right....
Do you really mean casting number P4532908?
Rich H.
Esse Quam Videri
Re: Mopar Performance R3 block [Re: begood] #2510485
06/19/18 07:18 PM
06/19/18 07:18 PM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
(continued).....if it is really a P4532908 casting number, then you've got what started out as a 9.200 water block with 340 mains.
Lifter bore angle was generic/enough material cast into it to be machined either way.
It would normally have been machined into either P4876672
or P4876792 Marketing/MP catalog numbers. Those can be Googled pretty easily or start checking MP catalogs. No idea if they even make these anymore but I am guessing probably not...
Rich H.
Esse Quam Videri
Re: Mopar Performance R3 block [Re: ZIPPY] #2510486
06/19/18 07:19 PM
06/19/18 07:19 PM
begood Offline OP
begood  Offline OP
My mistake. Yes it is casting number P4532908.
Re: Mopar Performance R3 block [Re: begood] #2510487
06/19/18 07:22 PM
06/19/18 07:22 PM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
Oh OK, well there you go, hope that helps.
I'm not directly involved with that stuff anymore having moved on in 2013 but have posted on that casting number before, so the info was floating out there in cyberspace.
Good luck with it!
Rich H.
Esse Quam Videri
Re: Mopar Performance R3 block [Re: ZIPPY] #2510489
06/19/18 07:31 PM
06/19/18 07:31 PM
begood Offline OP
begood  Offline OP
It has 792 stamped on the front of the block, so I'm thinking it must be a P4876792 block.
Re: Mopar Performance R3 block [Re: begood] #2510492
06/19/18 07:34 PM
06/19/18 07:34 PM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
Makes sense. I think we figured it out.
Rich H.
Esse Quam Videri
Re: Mopar Performance R3 block [Re: begood] #2510583
06/19/18 11:24 PM
06/19/18 11:24 PM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
Was that the one on racingjunk? There’s another one of those for sale to the west of me in Cal. I’d like to stumble onto another P4876671. Same deal as yours, but Siamese.
Re: Mopar Performance R3 block [Re: begood] #2510617
06/20/18 12:43 AM
06/20/18 12:43 AM
New Smyrna Beach FL
scottb Offline
scottb  Offline
New Smyrna Beach FL
I hope it’s not a 9.200 deck block with the wrong lifter bores in it the cams are hard to come by and very expensive
Re: Mopar Performance R3 block [Re: begood] #2511466
06/21/18 07:49 PM
06/21/18 07:49 PM
begood Offline OP
begood  Offline OP
No, this one was not on racing junk. It has 59 degree lifter bore. A cam will not be a problem.
Re: Mopar Performance R3 block [Re: begood] #2511468
06/21/18 07:54 PM
06/21/18 07:54 PM
pittsburghracer Offline
I don't know if this will help but I have it saved in my race tech.
https://www.jegs.com/InstallationInstructions/300/312/312-P4876381AB.pdf
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Mopar Performance R3 block [Re: pittsburghracer] #2511471
06/21/18 08:03 PM
06/21/18 08:03 PM
begood Offline OP
begood  Offline OP
Thank you very much.
Re: Mopar Performance R3 block [Re: begood] #2511488
06/21/18 09:21 PM
06/21/18 09:21 PM
You are very welcolm.
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: Mopar Performance R3 block [Re: begood] #2511591
06/22/18 01:46 AM
06/22/18 01:46 AM
ma.
duspan Offline
duspan  Offline
ma.
my friend has a 48 degree r3 block set up for dry sump? if you are int rested just let me know if there is number you are looking for, i know you can not get this block any more, this block can be converted to wet sump by the machine shop!
Re: Mopar Performance R3 block [Re: begood] #2511725
06/22/18 01:16 PM
06/22/18 01:16 PM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
There might be 340 replacement block coming out of mothballs to be sold soon. Priorities/thinning the hoard kind of a deal.
Rich H.
Esse Quam Videri
Re: Mopar Performance R3 block [Re: scottb] #2511954
06/22/18 11:13 PM
06/22/18 11:13 PM
bean town ....Ca
W
WHITEDART Offline
WHITEDART  Offline
W
bean town ....Ca
Brett Miller has one of those there is a fairly easy solution
In the 8s N/A.with Brett miller W8's
5.07 at 133 at 2700lb
