Re: Air filters
[Re: slomoshun]
#2510180
06/18/18 10:17 PM
06/18/18 10:17 PM
Posts: 11,484 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
Lot of guys use K&N without oil. Less restrictive, just trying to keep the big stuff out. Lots of different sizes and configurations available if you have an unusual space to get it in. Wix racing are also fine.
Re: Air filters
[Re: slomoshun]
#2510264
06/19/18 02:04 AM
06/19/18 02:04 AM
Thumperdart
State of confusion
What is best racing air filter besides k&n and I don’t want to have to clean and re oil This will be on a 800plus hp engine. Thanks in advance I threw and gave away my K&N crap and run WIX paper racing filters WAY better and less restrictive...........
Re: Air filters
[Re: slomoshun]
#2510288
06/19/18 08:00 AM
06/19/18 08:00 AM
Posts: 3,696 jersey
Spaceman Spiff
jersey
Curious as to why the wix racing filter says “ no for highway use” Is it just a disclaimer, or do these no actually filter well enough for a street driven vechile, that would see more dirty air, then a track car?
Re: Air filters
[Re: Spaceman Spiff]
#2510370
06/19/18 01:38 PM
06/19/18 01:38 PM
Thumperdart
State of confusion
Curious as to why the wix racing filter says “ no for highway use” Is it just a disclaimer, or do these no actually filter well enough for a street driven vechile, that would see more dirty air, then a track car? Yep, they filter big chunks, birds and other flying objects and you can see through em BUT, the 3" will flow 1000+ cfm and beyond........
Re: Air filters
[Re: slomoshun]
#2510408
06/19/18 03:09 PM
06/19/18 03:09 PM
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
I used an 11x5 K&N velocity stack base style assembly inside the hood scoop with an isolator plate. Didn't hurt it. I think it helped it. I don't think I would run one without an air cleaner anymore and K&N makes a lot of different sizes, shapes, panel filters, etc, that you can get a filter on just about anything. If a 14 or 16 x 3 or 4 round unit will work, you have more choices.
Re: Air filters
[Re: slomoshun]
#2510517
06/19/18 08:57 PM
06/19/18 08:57 PM
rowin4
I know they make special air filters such as the oval ones for 6 pac and the multiple carb units but can a round filter be made oval without causing total loss of filtering. Lets say 16" round to 13" -14" wide oval.
Re: Air filters
[Re: slomoshun]
#2510518
06/19/18 08:59 PM
06/19/18 08:59 PM
Posts: 2,853 Pattison Texas
CSK
Pattison Texas
I use the Wix racing filter with a pre wrap .
