Power steering conversion question #2509559
06/17/18 11:23 AM
06/17/18 11:23 AM
USA
440mopar Offline OP
440mopar  Offline OP
USA
I am going to be converting my car from manual to power steering and have a question about the column. I picked up a power steering column and would like to just swap the steering shaft from the power column I bought into the manual column in the car rather than swapping out the entire column. What I would like to know is, can I install the power shaft into the column in the car without removing the column from the car?
Re: Power steering conversion question [Re: 440mopar] #2509583
06/17/18 12:49 PM
06/17/18 12:49 PM
Supercuda Offline
Supercuda  Offline
That question might be answerable if we knew what car you are working on. I imagine a vert would not be an issue.
Don't be the exception.
Re: Power steering conversion question [Re: Supercuda] #2509623
06/17/18 02:52 PM
06/17/18 02:52 PM
USA
440mopar Offline OP
440mopar  Offline OP
USA
What I meant was can the shaft be freed up from the column housing/collar or whatever else holds it in the column in order to slide it out or would it be necessary to take the entire column out and do it on a bench.
Re: Power steering conversion question [Re: 440mopar] #2509624
06/17/18 02:56 PM
06/17/18 02:56 PM
Supercuda Offline
Supercuda  Offline
Yes
Re: Power steering conversion question [Re: 440mopar] #2509648
06/17/18 03:52 PM
06/17/18 03:52 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
The shaft comes out the bottom so it might be a little difficult without removing the K member - or you could just take out the column (probably easier !!)
Re: Power steering conversion question [Re: Stanton] #2509866
06/18/18 09:42 AM
06/18/18 09:42 AM
s.w.fl
bonefish Offline
bonefish  Offline
s.w.fl
they are easy to remove,ive found it helps to take out the front seat.
Re: Power steering conversion question [Re: 440mopar] #2510429
06/19/18 04:50 PM
06/19/18 04:50 PM
Connecticut
FurryStump Offline
FurryStump  Offline
Connecticut
As a side note I just changed from power to manual. 40 lbs lighter!!!
best of 11.39 at 117 mph 1.60 60’. 68 340 S Barracuda Fastback F.A.S.T [IMG]http://i67.tinypic.com/2mnnnnt.jpg[/IMG]
