Re: How to remove clear overspray on windshield
[Re: DartGTDan]
#2509850
06/18/18 07:28 AM
06/18/18 07:28 AM
Posts: 4,764 Holland MI Ottawa
2boltmain
Holland MI Ottawa
I would start with the least aggressive and proceed thru the scale getting more aggressive if needed. Light overspray I used a polish or compound.
Keep old mopars alive.
[Re: mgoblue9798]
#2510187
06/18/18 10:30 PM
06/18/18 10:30 PM
Posts: 7,664 IN
ahy
IN
If still pretty fresh, a rag with lacquer thinner should work. Be very careful not to spill any on or touch the rag on the fresh paint. Lacquer thinner has worked for me before. As mentioned be careful. Keep the can of thinner far away and put a small amount - finger size - on a fresh rag to remove the overspray. That way you will not damage the paint. A razor blade used carefully is good also... especially on edges where you don't want lacquer thinner to hurt rubber or paint.
