Hard to get into reverse #2508153
06/13/18 10:23 PM
06/13/18 10:23 PM
Carpinteria, Ca
H
hotcidr Offline OP
hotcidr  Offline OP
H
Carpinteria, Ca
My 70 Challenger 340/4 speed is very hard to get into reverse, all other shifting is great. Any advice on where to start on repairing this problem is appreciated
Re: Hard to get into reverse [Re: hotcidr] #2508173
06/13/18 11:02 PM
06/13/18 11:02 PM
Kirkland, Washington
Pacnorthcuda Offline
This one is easy, the side plate on the tranny needs to be loosened up, then you tap the rear/bottom portion of the plate UP--it will move a tiny bit, less than a 1/16". Then tighten the plate and try it.
The clearance, internal, for the reverse arm is very small, and is known to bind against the case. Very common
Re: Hard to get into reverse [Re: hotcidr] #2508196
06/13/18 11:28 PM
06/13/18 11:28 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
If you have not done it in a while you can adjust the rods, per the FSM.
Re: Hard to get into reverse [Re: hotcidr] #2508263
06/14/18 07:28 AM
06/14/18 07:28 AM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Start with the basics, air gap on the clutch disc
Re: Hard to get into reverse [Re: hotcidr] #2510613
06/20/18 12:35 AM
06/20/18 12:35 AM
Hamilton, Ontario Canada
Magnum Offline
Magnum  Offline
Is reverse hard to find with the engine off too? Or are we grinding while trying to engage reverse?
Re: Hard to get into reverse [Re: hotcidr] #2510633
06/20/18 01:29 AM
06/20/18 01:29 AM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
Are you running the bell housing that it left the factory with? If not is it a replacement or aftermarket?
Re: Hard to get into reverse [Re: ScottSmith_Harms] #2511149
06/21/18 12:25 AM
06/21/18 12:25 AM
Southeast Pa.
SALEM1912 Offline
SALEM1912  Offline
Southeast Pa.
Are you going from N to reverse,if so try going into a synchronized gear then right into reverse. sometimes you need to stop the input shaft esp if the clutch has a little drag going on.
