Page 10 of 10 1 2 8 9 10
Re: G's Mopar build thread (hemi, gerst, '69 Charger) [Re: gsmopar] #2705363
10/10/19 01:17 AM
10/10/19 01:17 AM
[quote=gsmopar]
The car has no problem doing a rolling burn out with a small blip of the throttle. I drove as much as I felt comfortable with running off the battery. Will order a Dayco TopCog belt tonight. The engine revs up QUICK. Definitely not something that I'm used to.
Sounds like it is time to work on the traction so it will set you way back in the seat at WOT and put a big old grin on your face up wrench work
Re: G's Mopar build thread (hemi, gerst, '69 Charger) [Re: gsmopar] #2705439
10/10/19 09:22 AM
10/10/19 09:22 AM
Mo.
racerx Offline
racerx  Offline
Mo.
Originally Posted by gsmopar
I must have lost the belt on the last test drive. Throttle linkeage fixed. I'm pretty sure that I fixed the oil leak (engine mount bolt on the side of the block. All I had was blue RTV, will see if it holds).
Old car cleans up okay. The hood is at The painters and should be done next week. My butt dyno says the hemi is faster than the wedge (wedge on nitrous). The car has no problem doing a rolling burn out with a small blip of the throttle. I drove as much as I felt comfortable with running off the battery. Will order a Dayco TopCog belt tonight. The engine revs up QUICK. Definitely not something that I'm used to.
[Linked Image]Untitled by Greg Ault, on Flickr
so what color was decided on the hood?
Re: G's Mopar build thread (hemi, gerst, '69 Charger) [Re: racerx] #2705450
10/10/19 09:44 AM
10/10/19 09:44 AM
Arizona, USA
gsmopar Offline OP
gsmopar  Offline OP
Arizona, USA
Body color.
Re: G's Mopar build thread (hemi, gerst, '69 Charger) [Re: Cab_Burge] #2705486
10/10/19 11:20 AM
10/10/19 11:20 AM
central il.
second 70 Offline
second 70  Offline
central il.
[quote=gsmopar]
( The engine revs up QUICK. Definitely not something that I'm used to.)
I know the feeling it's shocking how fast they rev. I have a mechanical roller and 4-speed. A good tach is nice but a rev limiter is a must.
I know some will get their feelings hurt but I learned about the TopCog belt from the Chevy Z28 302 guys. Another engine that revs so fast it loved throwing belts.
Mike
Re: G's Mopar build thread (hemi, gerst, '69 Charger) [Re: second 70] #2708989
10/21/19 07:47 PM
10/21/19 07:47 PM
Arizona, USA
gsmopar Offline OP
gsmopar  Offline OP
Arizona, USA
The new alternator belt is staying put so far. I did a quick run through 2.5 gears on a open country road. I need to add a second line from the driver side valve cover to my breather tank and re-bleed the front brakes (little squishy). The hood came back today! I'll do some final alignment and hopefully take some nice pics this weekend!
Re: G's Mopar build thread (hemi, gerst, '69 Charger) [Re: moparx] #2709012
10/21/19 08:42 PM
10/21/19 08:42 PM
Bitopia
jcc Offline
jcc  Offline
Bitopia
Originally Posted by moparx
usually, a support bearing is used when having three joints in a steering shaft, but due to you having a sort of long shaft sticking out of your column, and the standard "long" rack shaft, i think a support would be insurance against any possible deflection. here is a shot of the support on my humpback project. it's a 3/4", .007 oversize, heim joint, available in a bunch of places especially made for steering shaft support. the oversize allows for a painted shaft installation. my shaft runs from the firewall, through the header tubes to the support, then to the rack. the steering is very smooth in operation. just a suggestion i would do if possible on your setup because of the extended column shaft.
Looking at the op's steering column solution and yours, I thought the pictured solution induced cyclical velocity changes as the the column rotated when phased as pictured. I think many try to replicate a DS where the input and output angles are attempted to be same and because of relatively high RPMS , large torque inputs, and out of balance bending issues are dealt with, but none of which applies to a steering u joints. Here constant predictable steering angle inputs vs outputs are the goal,, ie constant velocity. Welded steering shafts also make me nervous.
I do like the project. up
"A configuration known as a double Cardan joint drive shaft partially overcomes the problem of jerky rotation. This configuration uses two U-joints joined by an intermediate shaft, with the second U-joint phased in relation to the first U-joint to cancel the changing angular velocity. In this configuration, the angular velocity of the driven shaft will match that of the driving shaft, provided that both the driving shaft and the driven shaft are at equal angles with respect to the intermediate shaft (but not necessarily in the same plane) and that the two universal joints are 90 degrees out of phase. This assembly is commonly employed in rear wheel drive vehicles, where it is known as a drive shaft or propeller (prop) shaft." From Wiki
https://en.wikipedia.org/wiki/Universal_joint#Double_Cardan_joint
Granted, not the highest tech source
Re: G's Mopar build thread (hemi, gerst, '69 Charger) [Re: jcc] #2709084
10/22/19 07:22 AM
10/22/19 07:22 AM
MN
JERICOGTX Offline
JERICOGTX  Offline
MN
The new hood looks very good on there.
69 GTX 68 Road Runner
Re: G's Mopar build thread (hemi, gerst, '69 Charger) [Re: JERICOGTX] #2710487
10/27/19 10:06 PM
10/27/19 10:06 PM
Arizona, USA
gsmopar Offline OP
gsmopar  Offline OP
Arizona, USA
[Linked Image]DSC06017 by Greg Ault, on Flickr
[Linked Image]DSC06015 by Greg Ault, on Flickr
[Linked Image]DSC06013 by Greg Ault, on Flickr
[Linked Image]DSC06012 by Greg Ault, on Flickr
[Linked Image]DSC06010 by Greg Ault, on Flickr
Re: G's Mopar build thread (hemi, gerst, '69 Charger) [Re: gsmopar] #2716589
11/17/19 12:01 AM
11/17/19 12:01 AM
Arizona, USA
gsmopar Offline OP
gsmopar  Offline OP
Arizona, USA
I'm on my second tank of gas and have leaned on it a little on the open road. So far so good! Can't wait to get this thing to the track and see what it does. Butt dyno says it's significantly faster than my old wedge. I did the local Cars and Coffee this morning:
[Linked Image]DSC06094 by Greg Ault, on Flickr
[Linked Image]DSC06089 by Greg Ault, on Flickr
Re: G's Mopar build thread (hemi, gerst, '69 Charger) [Re: gsmopar] #2716733
11/17/19 02:05 PM
11/17/19 02:05 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
You make me proud to be part of this bad ass build and awesome street car.............
Re: G's Mopar build thread (hemi, gerst, '69 Charger) [Re: gsmopar] #2716752
11/17/19 02:52 PM
11/17/19 02:52 PM
Mo.
racerx Offline
racerx  Offline
Mo.
Nice car ….. cool
Re: G's Mopar build thread (hemi, gerst, '69 Charger) [Re: gsmopar] #2716783
11/17/19 04:21 PM
11/17/19 04:21 PM
ONTARIO,CANADA
604 Hemi GTX Offline
ONTARIO,CANADA
Car looks awesome!!!!
One question who scoop is that?
I’m planning on doing the same scoop on my 70 GTX
Kevin
Re: G's Mopar build thread (hemi, gerst, '69 Charger) [Re: Thumperdart] #2716919
11/17/19 09:38 PM
11/17/19 09:38 PM
Arizona, USA
gsmopar Offline OP
gsmopar  Offline OP
Arizona, USA
Thanks buddy! I can't wait to tag you in the first nitrous pass video!
Re: G's Mopar build thread (hemi, gerst, '69 Charger) [Re: 604 Hemi GTX] #2716920
11/17/19 09:39 PM
11/17/19 09:39 PM
Arizona, USA
gsmopar Offline OP
gsmopar  Offline OP
Arizona, USA
Kevin
http://glasstek.com/
Re: G's Mopar build thread (hemi, gerst, '69 Charger) [Re: gsmopar] #2716993
11/18/19 01:10 AM
11/18/19 01:10 AM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Hell ya.....spray away.......
Re: G's Mopar build thread (hemi, gerst, '69 Charger) [Re: Thumperdart] #2720511
11/30/19 08:35 PM
11/30/19 08:35 PM
Arizona, USA
gsmopar Offline OP
gsmopar  Offline OP
Arizona, USA
Re: G's Mopar build thread (hemi, gerst, '69 Charger) [Re: gsmopar] #2720526
11/30/19 09:41 PM
11/30/19 09:41 PM
Tire smoke on demand grin up
Now comes the hard part, making that powerful Hemiriod motor NOT spin the tires so bad in your car whistling wrench up
Can you imagine a wheelie devil H--- yeahboogie
Re: G's Mopar build thread (hemi, gerst, '69 Charger) [Re: gsmopar] #2720531
11/30/19 10:31 PM
11/30/19 10:31 PM
Pittsburgh,PA
RTSrunner Offline
RTSrunner  Offline
Pittsburgh,PA
That revs up quite nicely! Very cool
Re: G's Mopar build thread (hemi, gerst, '69 Charger) [Re: gsmopar] #2720621
12/01/19 01:02 PM
12/01/19 01:02 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Can't wait to see some new best et's.....
Re: G's Mopar build thread (hemi, gerst, '69 Charger) [Re: Thumperdart] #2734613
01/19/20 07:18 PM
01/19/20 07:18 PM
Arizona, USA
gsmopar Offline OP
gsmopar  Offline OP
Arizona, USA
I really need to get to the track so I quit doing stuff like this:
